Which Paint works best for Vinyl Kits?
Posted by Anonymous on Sunday, March 21, 2004 6:13 AM
Just need a bit of advice for a vinyl kit I am going to build in the near future.
Which paints would work best for this type of kit - acrylics or oils?
Posted by Anonymous on Sunday, March 21, 2004 10:56 AM
I used modelflex and other acrylics with good results.
John
Posted by Anonymous on Monday, March 22, 2004 1:00 PM
Cheers for the tip, I will give it a go Thumbs Up [tup]
Not sure what Modelflex is (may have a different name in the UK) - excuse my stupidity on this Confused [%-)]
Posted by Anonymous on Monday, March 22, 2004 8:30 PM
Model flex is paint put out by Badger. Make sure you wash the vinyl kit before painting.
John
Posted by Anonymous on Tuesday, March 23, 2004 12:01 AM
Use acrylics. Enamels will never dry on vinyl.
    December 2003
Posted by Enzo_Man on Tuesday, March 23, 2004 12:06 AM
Hungfarlow is right. On my first vinyl I used enamels, stuff never dried totally. It stated VERY tacky. Acrylics all the way, man!
Aerodynamics is for people who can't build engines.
    January 2004
Posted by joewhite on Tuesday, March 23, 2004 12:19 AM
I too was searching for a good primer for vinyl. I called Krylon and Plasti-Kote but they said that their primers would not go good with vinyl, or acrylics for the rest of the paint-job. After visiting a automotive paint store, I decided that I would try a Flexible Primer Surfacer #39133 made by SEM Products. I called the company and they weren't really sure it would work for vinyl kits. Well, the man at the store who sold it to me said that he knew it was sometimes used for car vinyl tops, and of course bumpers and other flexible surfaces that the stuff was intended for.
I was a little hesitant to spray but I think I remember the guy at the paint store saying it was a lacquer based primer. Being that fine folks in this forum have stated that lacquers actually do go well over vinyl, I figured it was safe. I sprayed a part of my kit. I accidently oversprayed one part but to luckily no meltage (lacquers being hot which could damage some plastics if applied heavily). It dried quick and firm, something I would expect from priming normal styrene models which I am more used to building.
Although Krylon said not to try their paints on my kit I went ahead and sprayed a spare piece and although it didn't stay tacky, it didn't feel very well cured and I wasn't happy with the feel of it.
I hope this little bit of info helps somehow...I know exactly how it feels when building a vinyl kit. But I can't complain, it really is a lot of fun. Peace!
Posted by Anonymous on Tuesday, March 23, 2004 1:38 PM
Thank you very much for the advice on this, this is going to be the first vinyl kit that I've done and I do want it to look good at the end of the day. So I will give it a go with acrylics.Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]
    May 2003
Posted by qmiester on Tuesday, March 23, 2004 8:05 PM
I've only done a couple of vinyl figures. I primed them with flesh colored acrylic paint, let it dry two or three days and then painted it with oils. Has worked well the times I've done it.
Quincy
