painting brass
painting brass
Posted by upnorth on Monday, March 22, 2004 7:48 PM
I've just recently made some rear view mirror armatures out of brass rod to replace the rather frail plastic ones in an armor kit I'm working on.
I've worked a bit with small PE brass components, but nothing quite as large and sturdy as the armatures I've just made, so i'm a bit lost as to the best way to put paint on them.
Should I rough up their surface slightly for better paint adhesion?
What's a good primer to put on brass parts?
Will acrylics cover brass well, or am I better to go with enamels?
Answers to those questions and any other adice you can give on finishing such brass components would be greatly appreciated.
Thanks in advance
    January 2004
Posted by MusicCity on Monday, March 22, 2004 9:49 PM
Just guessing here, but if it were me I'd try priming them with automotive primer. It is designed to adhere to metal so it should stick to the parts fine. The acrylic color coat will then adhere to the primer much better than it would the metal itself.
    May 2003
Posted by DrCemento on Friday, March 26, 2004 4:53 PM
first, clean the brass and soak in white vinegar for a couple minutes, then lightly sand with 220 grit and clean up again. then DEFINENTLY prime with something - my favorite primer right now is Tamiyas plasict/metal primer - this stuff also accepts acrylics very well the vinegar is sort of etches the surface and makes it remarkably better at accepting paint. good luck
Model builder formerly posting as jbatesc6
Posted by Anonymous on Friday, March 26, 2004 6:16 PM
sand 400,. then prime w/ lacquors (preferabbly, or enamals) then spray on top.
