Airbrushing acrylics woes
    February 2017
Posted by The Wargamer on Wednesday, February 22, 2017 7:39 PM
Hello all!
I'm looking for someone to school me on the art of using acrylics in an airbrush.
Now, I'm not necessarily a noob to the Airbrush or to building models.. I grew up building an painting military scale models with my dad since I was a kid. He had one of the better Testors Aztek Airbrushes which I thought got the job done pretty well. I only had experience with enamels through that airbrush though.
Now I have an Iwata HP-CS and I've mostly used Games Workshop's Citadel acrylics and Vallejo's acrylics (both air and model colors). I've been using my HP-CS for over a year with those brands of paint and I really thought I had gotten my ratios down had worked out all the kinks in my process.. but after shooting some decanted Rustoleum spray paint through my airbrush yesterday and being blown away by the ease.. and then got hung up in frustration by trying to go back and shoot a few acrylics.. I decided to get on the internet and see what some of the veterans had to say.
Right now my set up is:
HP-CS
90s Badger Compressor (moisture trap on pressure guage no airtank)
I normally set my pressure anywhere from 20-35 PSI.
The issue I run into (more so with lighter colors like greys and whites) is the paint getting too dry too fast. My remedy was to shoot those pigments much more on the thinner side which prevented clogs and gave me a slightly (emphasis on the slight) longer working time but I feel like I've lost so much control in the process. I don't know if anyone has used Citadel paints but I had a super easy time airbrushing their washes and I've also been using some of Tamiya's clear red acrylic paint with Tamiya thinner and thats been very easy to use. I notice a lot of "graininess" and "dustiness" when shooting the lighter pigmented colors which I've concluded is from the paint drying in the air before it reaches the surface.. correct? I also get tip dry really quickly and clogs in the nozzle come pretty fast as well. Some of it may be related to needing a new nozzle but I think I'll need to post a different thread in reference to that.
Some of you may say "why not go back to enamels" and honestly I've thought about it. However, I'm using these paints on Warhammer 40k/30k armies and I don't want to have so much variance in color between the units in my Army. I suppose I could also try to color match but I feel like it would be a really expensive route buying different paints to try and color match. I also like the convenience of being able to airbrush indoors.
A few last notes, for thinner I'm mostly using Vallejo's acrylic airbrush thinner and testors acrylic airbrush thinner. It appears most people on the interwebnets like to make their own mix of distilled water, flow aid, matte medium, and some kind of retardant in whatever ration they've developed for themselves. I know that would be pretty cost effective but is that really the best thinner to use for acrylic paints? I've never used flow aid before but from what I read I think adding some to my process may help.
Thanks in advance everyone!
    October 2010
Posted by hypertex on Friday, February 24, 2017 6:56 AM
What you are describing is called "dry spray." It seems it is quite common for enamel users who switch to acrylics to experience this. The solution is threefold: 1) spray closer to the model, don't be afraid to get in close; 2) add more thinner--when you think you've added enough, add a bit more; 3) reduce air pressure. There is no magic number that works for everyone, but I usually spray between 15 to 20 PSI.
You are doing the right thing in starting with the manufacturer's recommended thinners. But you could try a little retarder. Use a liquid retarder and not the gel kind. I use Winsor and Newton Galleria retarder. It even works with Tamiya paint. I would suggest adding no more than 5 or 10%.
    May 2013
Posted by Greg on Friday, February 24, 2017 9:35 AM
I think you need to get your needle/nozzle replaced as Don said in the other thread, get that air pressure down a little bit as Hypertex mentioned above, and start anew.
The dry tip is probably never going to go away 100% spraying acrylics, but with some tweaks of proper products and ratios you will be able to make is almost go away.
Do hope you let us know when you get the new tip/nozzle. BTW, Hobbylobby usually stocks them. You can get two coupons, make two trips in if you want to be a nut like me.
    April 2006
Posted by jgeratic on Friday, February 24, 2017 11:48 AM
All great tips, and one more I can add is thinning with pledge future clear product - as long as a gloss surface is part of your air brushing stage.  Also, keep a wet brush handy to wipe the needle tip if paint starts to dry on you.
regards,
Jack
    February 2017
Posted by The Wargamer on Friday, February 24, 2017 3:58 PM
Gentlemen, thank you very much for all the responses.
-hypertext I did a lot of research on the internet about airbrushing and the HP-CS in particular as it was the first gravity fed brush I've ever used. I read basically what you said that 15-20 PSI was around the pressure that it should be operated at. In my experience there was always something off with the spray pattern when I would shoot at the pressure. Now this may just be my lack of experience with an airbrushed.. but it seemed to me like a lot of what I would describe as overspray. By that I mean if I was spraying a centered pattern there would be a while defined center but out side that there would be a lot of speckles similar to the "dry spray" you mentioned. I guess I don't have a real reference to what a "normal" pattern would look like for an Airbrush but I figured it would be a lot tighter and more accurate than it was. Then again I was not shooting as thin as you were suggesting.
The other issue I had with shooting at a lower pressure like 15-20 PSI was not being able to spray fine details very well, i.e. panel lines on armor or aircraft for shading as well as creating shadows on the minis that I game with. I would have a much wider pattern as I got close to the component that I was working on and not the tight fine pattern I needed. I feel it got a little bit better when I shot 25-30 PSI. "Spidering" is another issue I had when going really then and getting the airbrush nozzle close to whatever model I was shooting. Any tips for that?
I have some Vallejo medium retarder that I try to mix in with the paints I brush but it is very thick and I'm not entirely sure it does the job it's supposed to do. I'll try and look at some of those brands you mentioned.
-Greg I will absolutely check for some coupons because the last time I went to hobbylobby the nozzles seemed much more expensive than they were online.
    March 2013
Posted by patrick206 on Friday, February 24, 2017 4:50 PM
I agree with pressure reduction, most of my acrylic spraying is at 15-20 psi, regardless of paint brand.  Currently I use Tamiya acrylics, thinned with X-20A. For additves I use Liquitex Flow Aid or Slo-Dri.
I keep a small tin of alcohol on the bench and a Q-tip at the ready, for a once in a while swipe of the needle/nozzle end. It will tell you when it's time. If you use a pressure regulator, should the AB act up a quick spray at 25-30 psi, will help to get some of the build up and partial drying/thickening in the nozzle interior blasted out.
For the most part I keep the AB relatively close to the surface, that reduces the tendency for particles to partially dry on the way to the object. Also the reduced pressure will prevent creating a fine mist that can place gritty, dried bits on the surface.
Patrick
    May 2013
Posted by Greg on Friday, February 24, 2017 6:55 PM
Just FYI,
Vallejo retarder medium is not designed for airbrush use. It has something to do with hand brushing if I recall. It'll make things much worse in a airbrush (in my experience anyway).
In my experience Vallejo product nomenclature can be confusing sometimes misleading. I'm not throwing stones at Vallejo, they are my go-to acrylics.
One other thing just came to mind. If you want to mix anthing with your Vallejo acrylics (airbrush thinner, flow enhancers, etc) my two cents would be to stick with Vallejo products only.
    February 2017
Posted by The Wargamer on Friday, February 24, 2017 8:47 PM
-Greg, I'll keep that in mind on mixing Vallejo products with Vallejo acrylics. Vallejos AB thinner and Testors acrylic airbrush thinner smell like pretty much the same solution to me an appear to work just as well as the other which is why I started using the testors (not to mention more volume). I'll let you guys know what's up once I get a new nozzle. I will also try to post up some spray patterns at various pressures so you guys can see what I'm working with.
