What cheap medium can I practice air brushing on?
    February 2017
Posted by ugamodels on Sunday, February 26, 2017 9:00 AM
What is a cheap medium that best mimics plastic? I want to practice with my Paasche H airbrush but I want something that will have the same general properties as plastic, but is cheap. Will poster board work, or will the paint run too much? Will cheap kid's acrylics spray the same is modeler's acrylic?
I type on a tablet. Please excuse the terseness and the autocorrect. Not to mention the erors.
    July 2004
Posted by stikpusher on Tuesday, February 28, 2017 9:56 PM
how about an old build? I had an old Monogram P-51B that I had built as a kid but had been damged beyond repair for display purposes that I used as a test mule for many years. I also used a simple sheet of cardboard to get the feel of new paints or trying to get a setting right before moving to the actual project.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Wingman_kz on Tuesday, February 28, 2017 10:18 PM
It would be flat but a For Sale sign or the like would work. They're usually white on the back and if they aren't styrene they're the next best thing. I've read quite often about people using them for scratch building. If you're using acrylics it would be pretty easy to wipe off and reuse. Practice is practice but using your regular paints would be the true test.
That said, while it doesn't mimic plastic, I went to WalMart several years ago and bought a very small desktop easel and watercolor pad to practice airbrushing on. Color tests or seeing how fine a line I can pull. Nothing expensive and I thought anything that would keep me shooting paint was a good thing. :-)
    January 2009
Posted by fermis on Tuesday, February 28, 2017 11:13 PM
If you don't have an old build to use as a "paint mule", you could use the inside/unseen areas of a new kit....like the inside of a wing or fuselage...tank hull..etc. You could buy a box of plastic spoons from a dollar store. I'd also recommend using the same paints that you'll be using on your models. Different paint act different ways!
    October 2008
Posted by Don Wheeler on Tuesday, February 28, 2017 11:16 PM
Empty plastic bottles are free.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
Posted by Wingman_kz on Wednesday, March 1, 2017 1:04 AM
Don Wheeler
Don
Very true Smile
    April 2004
Posted by Jon_a_its on Wednesday, March 1, 2017 2:38 AM
Buy one of those cheap children's colouring-in books to practice on, will help with learning to spray between the lines.
Don't use cheap kids poster paints, except on groundwork, you wouldn't put gravel in your washing machine/tumble drier would you?
You certainly can spray it, but it's more like pebble-dashing & won't help you learn how to handle hobby paints.
You can use cheaper non-permanent Indian-inks or food colouring to practice with, much easier to clean up, less likely to need HazMat conditions & SwiMBO will be happier.
Airbrushes were originally used by illustrators to spray inks, guache, & acrylics, key points their thin-ness and Opacity/Transparancy...
You should consider the best airbrush and quiet compressor you can afford, as 'running out of canned-air' anxiety is real & canned air gets very expensive quickly.
Once you had practice on paper, then use a scrap/range target/donkey/yard sale/dollar store plane/car/tank to practice with paint on your intended target.
Good luck
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Tojo72 on Wednesday, March 1, 2017 5:45 AM
Old kits
Posted by Don Stauffer on Wednesday, March 1, 2017 8:39 AM
I get a lot of advertising flyers in the mail that are glossy, fine cardboard.  They seem to have a plastic-like coating on them, and take primer and paint very well.
Also, I have used, and have friends that have used, the plastic from blister-packs.  Once you have bought something that is packaged that way, and removed the item, through away the cardboard back but save the clear blister.  It paints very well.
    April 2008
Posted by Kizzy on Wednesday, March 1, 2017 1:48 PM
When I first started airbrushing, I bought a few large sheets of thin styrene to practice on.  They came in a pack of 2 or 3, and it cost about $5 or so.  The price might be a little more now, but probably not by much.  Since I was using Tamiya acrylics, when the sheet got used up I'd just wash off the practice paint with Windex, and it was like new again.  Even now, I still use them to test my paint before applying it to my model.  And if down the line, you need some styrene for a project, you have some.  Just cut from the sheet to the size you need and away you go.
-Kizzy
    February 2017
Posted by ugamodels on Wednesday, March 1, 2017 10:12 PM
Thanks everyone! Where did you buy sheet styrene from? This is the thought I had also, but all I see is Evergreen which is rather pricey. I live the sign idea, if I can find one with a white back.
FWIW, I don't have any old kits or models, and I intend to use the paint I plan to use on the models. But what I am reading about airbrushing Vallejo acrylics, I am starting to rethink my choice, at least for airbrushing.
Will regular amonia work for cleaning off acrylic? We don't keep Windex around.
    February 2017
Posted by ugamodels on Wednesday, March 1, 2017 10:17 PM
I actually still have my old Badger air compressor, and it still seems to work! And if it fails I have a tank compressor that I can fall back on.
    April 2008
Posted by Kizzy on Thursday, March 2, 2017 12:03 PM
I bought the sheet styrene from the LHS.  It was several years ago...can't recall the brand.  Evergreen can be a bit pricey, I agree.
Yes regular ammonia will work for most acrylics, if you can handle the smell!  You could also make a solution of 5% ammonia in distilled water.  I believe that is the approx. percentage in Windex.
    September 2016
Posted by ManCityFan on Thursday, March 2, 2017 2:35 PM
Don Wheeler
Don
Ditto
I have two or three empy clear plastic soda bottles in my work area, and always test paint in the airbrush on them before I move to the model.  Gives me a chance to thin or adjust air pressure before I potentially screw up a model.  I also use the caps to hold small amounts of paint when using a brush and not an airbrush.  And yes, I leaned this from Don's website, which, by the way, is awesome.
Dwayne or Dman or just D.  All comments are welcome on my builds.
    February 2017
Posted by ugamodels on Thursday, March 2, 2017 7:58 PM
The plastic bottles I am familiar with seem very slick for painting.  What type are you thinking of?
Also is there a good reference Web site for identifying plastic; ie type, what paint will stick, what type of glue, etc?
    October 2008
Posted by Don Wheeler on Thursday, March 2, 2017 10:26 PM
The shiny plastic bottles take model paint just like kit styrene.  If you can paint on one, you can paint on the other.
Don
    May 2009
Posted by Pawel on Friday, March 3, 2017 2:58 AM
Hello!
You could probably also use plastic boxes that ice cream comes in. Some of them are made of styrene - you can see that by looking at the triangular marking with PS letters inside - that's styrene. By the way you can also practice washing and surface prepping, because they can be a little greasy... But after you eat the ice cream, they are free! Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    October 2008
Posted by Don Wheeler on Friday, March 3, 2017 11:12 AM
Here is a nice summary of the meaning of those recycle symbols on plastic.
Don
    June 2003
Posted by Jammer on Friday, March 3, 2017 4:52 PM
Comic book backing boards.  It's higher quality cardboard with a fairly non-porous surface so the paint doesn't soak in to it.  I keep one next to my airbrush to test colors and troubleshoot the airbrush.  Comes in packages of 100 for less than $10.  I stopped buying comics a few years ago, but the boards still have so many uses; backing for decal storage (I put aftermarket decals in comic bags with backing boards for sorting and storage), home made counters for wargames, wargame box repair, dividers in craft storage.  They're part of my model buidling and gaming tool kit.
Doug
    February 2017
Posted by ugamodels on Monday, March 20, 2017 8:09 PM
Hey Don,
So I can use the #1 (PET) clamshells that we get lettuce in for tests? Because we get lots of those!
    October 2008
Posted by Don Wheeler on Monday, March 20, 2017 9:46 PM
ugamodels
Hey Don,
I don't see why not.  You've got nothing to lose by trying.
Don
