Rough gloss finishes
    August 2012
Posted by JMorgan on Monday, March 13, 2017 6:12 AM
what makes an airbrushed gloss lacquer turn out a rough finish that needs sanding and polishing to look right?
Posted by Don Stauffer on Monday, March 13, 2017 8:53 AM
Lacquer dries very fast, so does not flow out to a smooth surface as well as a slower drying paint, such as enamel.  However, because it dries hard, it can be polished well.  Rubbing out a fresh finish was always part of car painting.
If the surface is really rough, most common reason is that it is drying on way to surface- either pressure too high or holding airbrush too far from surface.
    November 2003
Posted by mississippivol on Monday, March 13, 2017 9:03 AM
Dittos to what Don said.
    August 2012
Posted by JMorgan on Monday, March 13, 2017 9:33 AM
The surface was a flat coat of a color only available in that texture. I will hold the airbrush closer in the future. Thank you.
    April 2016
Posted by Hodakamax on Monday, March 13, 2017 10:18 AM
I sometimes have the same problem with acyrlics. You might experiment with more thinning and try to keep all surfaces wet when spraying. Practice makes perfect and I still have a way to go!
Max
    September 2016
Posted by SaltydogII on Monday, March 13, 2017 2:21 PM
All good points above. Surface prep is key as well to a gloss coat. the smoother the underlying surface, the better the gloss coat. Also, I would recommend Mr. Leveling Thinner. Yeah, its $15 for 400ml, but it is well worth it. It has an additive that slows drying time and assists in leveling your paint. It thins lacquers, Tamiya paints, enamels, and of course Gunze, and works awesomely. To get a really fool proof gloss coat, I learned this little trick from a FB group that works exceptionally well. Get some Tamiya X-22 clear and thin it with Mr. Leveling Thinner and apply. When your done applying this mixture, load straight Mr. Leveling Thinner into your airbrush and apply a wet coat of straight MLT. 3-5 minutes later, you have a gorgeous gloss coat, even if you didn't apply the X-22 evenly. Works awesome.
Chris
