Tamiya X-19
    May 2015
Tamiya X-19
Posted by IEDDTEK on Wednesday, March 22, 2017 3:25 AM
There seems to be a lot of confusion as to just what Tamiya X-19 Smoke was created for...and especially how to apply it. Specifically with an a/b. I have it...I want to use it on a 2 piece canopy so that it looks tinted...not painted. I have found no vids proclaiming anything positive about this stuff...only complaints. But I figure that people just aren't using it properly. Does anybody out there have a good deal of experience w/this? And had good results?
TIA
    March 2017
Posted by Lord Voyager on Wednesday, March 22, 2017 7:18 AM
Hi there,
I have quite a few uses for X-19 and none of them involve swearing...
1) I thin it down and then run it around landing gear wells, tire hubs, anything that needs depth. when it dries, it clings to the walls and creates a shadow... Works best if the subject is done in enamel paints but acrylics are ok to...
2) varnished wood - mix this 50/50 with tamiya clear orange and you get a dark and very realistic varnish for anything that is wood... WW1 propellers, struts, etc. Play with the ratios to your taste.
3) I have a wide-mouthed sealable jar of Future clear to dip canopies in... I add up to 10% of X-19 (basically a whole bottle to one mason jar of Clear) and this will help make canopy scratches and flaws disappear a little better then just Clear alone.
I also add it to any tamiys paint I'm airbrushing to impart a touch of gloss AND shadow at the same time... Just watch your ratios. I've also airbrushed it as a way to tone metalics around exhaust stained metal.
Good luck, hope this helps.
"The Grid. A digital frontier. I tried to picture clusters of information as they moved through the computer. What do they like? Ships, motorcycles. Were the circuits like freeways? I kept dreaming of a world I thought I’d never see. And then, one day… I got in.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, March 22, 2017 9:08 AM
X-19 Smoke is actually a clear color like clear blue, green, or red, Uses for tinted windows, etcs....
    May 2015
Posted by IEDDTEK on Wednesday, March 22, 2017 3:54 PM
WOW! That really DOES help! Thanks a mil for that info! I have renewed confidence it now and will try that 10% trick on the canopy pieces. What is your ratio to thinner when you use it as a shadow-maker?
    May 2015
Thanks!
    May 2015
Posted by IEDDTEK on Wednesday, March 22, 2017 3:55 PM
