OK, got my Omni 4000 on Monday arvo, couldn't beleive my eyes, 4 working days from Coast AB to the middle of Oz, I almost cried
Anyway it has me a little miffed.
First usage I had paint dripping from the end, figured it was the needle seating, adjusted as required, all is well.
But when I tried to spray, I managed to get a fine line for about 30mm, and then it stopped.
Cleaned the tip, got around 50mm of spray length, stopped again.
I use Tamiya and Gunze Acrylics mostly, and allowing for the dry time I adjusted my air pressure both upwards and downwards, from 5 psi to 40 psi, not all at once, but testing at different intervals, not a lick of difference did it make.
I'm stumped as to whats going on, and dare I say it, with my Aztek 470, I never had tip dry, so naturally if there is a simple solution to this problem, I do not know it.
Mind you, the fine lines I did get blew me away, I glanced over to the Aztek, frowned, and put it on the shelf for my brother to practice with.
Are there additives for acrylics to reduce their drying time?
Any home made remedies etc?
Any help would be appreciated.
And bare in mind I live in Australia, so the galaxy of products available in the US, are not legally imported into this country, which really cramps a creative mind
Thanks in advance
Sean
BTW, the thinner I use is Tamiya X20A, don't know if that makes a difference, but thought it was worth mentioning.
Thanks
