Great advice from Bish and Greg. You'll find that properly thinned acrylics will spray much differently than what you used that many years ago. Before you start painting the actual model, I'd say get a couple extra bottles of paint for plenty of practice and getting used to handling the airbrush, pressure settings and thinning ratios.
Practice is best done on a smooth, hard surface, not paper or cardboard. Big plastic jugs are good, large surface area and they replicate model surfaces. Have you had a good look at "Don's Airbrush Website" yet" Great info found there, a good time investment.
I mask canopies off the model, much easier to handle. As much as possible I even spray the masked canopies off the model, IF I'm confident of the fit and that I won't need filler. I use the tacky contact kind of adhesive for canopy attachment, so I don't have to risk paint damage by plastic type cement.
Both Aleene's and Elmers white do the job for me, but they are not at all meant to hold forever, handling for dusting can remove them if bumped. In that case, just re-apply.
I'm a real Badger 200 fan, you'll find yours will do some fine work for you. If you find time, please let us know how you get on with your efforts. Best of luck.
Patrick
