Hello,
I have recently began any sort of "serious" modelling in 1/72 scale. Before I'd build a kit, be it a tank or plane, and paint it however I thought it looked good. For example, my first armor kit was a Revell Tiger E and I painted it olive drab because that's how it appeared on the box art. Only recently I have began to get into historically accurate modelling, mainly through paints. Over the last year or so I have built up a good-sized collection of Tamiya, Model Master, and most recently Vallejo paints. When I began, I used Testors enamels but I was sick of messing with paint thinner and the mess. Now everything I buy is acrylic, but I am having serious issues with many of my paints. They all seem too thin. I only use brushes and everything I have should be fine for brushing (I have Vallejo Model Color not Model Air, etc.) This is difficult to descrbie (especially because my paintng vocabulary is limited), but basically when I brush any paint on (I only model plastics) it does a poor job of covering anything, there are very obvious brush marks, and making anymore strokes with a brush just wipes everything around. It gets "streaky". It's like I am using a very thick wash rather than an actual paint. I have this problem with paints from all ranges; I'd say at least 2/3 of my paints are problematic. Some, like Vallejos Brown Violet or Tamiyas Fieldgrey are good, but those are exceptions. It was terrible trying to paint the deck of a model Arizona with Vallejo Orange Brown - I had to use about 5 coats. Vallejo White was probably the worst, I had to use about 7 or 8 coats. Some, like the Model Master Olive Drab, only needs about 1 or two coats to be good. I am also having a similar problem with Vallejo Black Primer. I cannot figure out what is going on. When I used Testors enamels, I used to have this problem when it wasn't thoroughly mixed, but a quick stirring would even out all the sludge and the paint would work well. Now, even after 5 minutes of shaking and literally using a paint brush to stir up my acrylics, it still seems too thin. I purchased much of this paint online and it was delivered during winter (I live in MN); I thought this might be the problem but even paints delivered in warm weather are turning out bad. What is going on? Is there some way to thicken paint? I really do not want to throw out the paint as I have at least $100 worth. Is there some special technique for mixing or applying acrlyic paints to plastic that I am missing?
