fotofrank
Patrick, thanks for your input. I really do appreciate it. My airbrush is a Badger 200 Detail and it's a siphon feed. I had a Badger 200 some forty years ago when I was last in the hobby.
As for manual cleaning, I have some Q-Tips and brushes, I need to get some pipe cleaners to clean the tube in the paint jar. I used the Mr. Color thinner and the Iwata Airbrush Cleaner to clean the brush after I sprayed today. That stuff is going to used up fast, I think.
For the part I painted earlier today, I think the pressure was set too low (15-20 lbs) and I held the brush too far from the wing so the primer was drying somewhat before hitting the wing. The surface isn't real smooth like I wanted. When I put color over the primer later, the roughness of the primer really showed through. I'll try another piece tomorrow and increase the pressure somewhat to see if I get a smoother finish.
I will definitely get a container to keep the excess material in prior to disposal. The hazardous waste disposal is about twenty minutes from the house.
I need to get some Tamiya masking tape then in various widths, I guess. About the only thing I'll be masking is anti-glare panels on Mustangs and a T-6. Nothing very extreme at all. BTW: I have Don's Airbrush Tips bookmarked. I need to go read some more of his information.
Thanks again for your input, Patrick
FotoFrank - I recall now you did mention it's a Badger 200. Excellent AB, it will serve you very well. When you bought it, did it have both the glass jar and metal cup?
Check Don's site, he shows examples of cleaning tools that work well. I buy my lacquer thinner at local paint store, quality is better assured there than the discount stores. I use the DuPont name, about $7 for a quart. Cheaper ones were suspicious in terms of quality. That and Acetone are the most effective cleaners.
I use interdental brushes for the largest amount of cleaning equipment, they hold up to lacquer thinner, the little one piece green plastic ones don't, they melt. For the nozzle I use a toothpick, I sand the end down until it passes through the small tip end of the nozzle. No need for any force, the tip end is a bit delicate and can be distorted if un-needed pressure is applied.
I do almost all of my spraying at 12-20 psi, usually 14-18 psi. My guess is the pebbly primer finish was applied at a little too much distance from the surface. That does allow the fine paint particles to dry before settling on the surface. If the paint passes are done too fast, that can also cause it. A major point is use the best lighting you can, the paint spray pattern is best seen, when you have the subject very well lit and visible.
I try to spray at a 90 degree angle to the surface, as much as possible, that prevents blowing paint particles at a shallow angle, onto adjacent areas. For a spray distance I'm rarely closer than 1/2 inch, usually 1 inch. It seams you did the primer thinning OK, for my use it's Badger's Stynylrez, never had to thin it yet.
Looks like you're off to the races, I still recommend some big, smooth plastic jugs, without texture. They will give you the true results of your spray practice sessions, by accurately replicating the surface of a model.
I'll bet with some more practice, varying distance, pressures and thinning ratios you'll have it in the bag. I enjoy your reports of progress, let us know of your results if you find the time.
Patrick
