If you are using an airbrush, spray the lighter bottom color first. I usually mask off the bottom of the wings and elevators after the bottom color is on, then spray the upper color freehand. Hold the AB at a slight upward angle and spray a light coat on the edge and work up with heavier coats as you get away for th meeting area. Fairly easy to replicate. Practice on a milk jug or some scrap, you will get the hang of it in no time.
As an aside, at one point in the war, Navy aircraft on the carriers had a 3 tone paint scheme, white/gray, medium blue and dark blue going from bottom to top.
