- Member since
Posted by MikeV
on Friday, March 26, 2004 7:39 PM
QUOTE: Originally posted by MusicCity
I had seen the Createx Extender somewhere, but, like you, I didn't think it was a retarder so I didn't get any.
I have a half-full quart bottle of Createx extender so I guess I could try it.
I use it for spraying onto a T-shirt before painting to get the knap of the shirt's fibers to lay down flat for a smoother surface. I spray it on, heat set it and then it is ready for painting. I still think that adding it to modeling acrylics though will only make them less intense and may even affect the value of the color. I may be wrong though as that is what it does to the Createx paints I have, but they are transparent and not opaque so that may make a difference.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
- Member since
January 2004
Posted by MusicCity
on Wednesday, March 31, 2004 9:24 PM
QUOTE:
Let us know what you find and how it works out.
Mike, I found some Createx retarder at the art store Friday but haven't had a chance to try it until tonight.
It really seems to make a difference, and a little bit goes a LONG way. I had mixed quite a bit of dark sea blue for my Corsair, most of a 3/4 oz bottle full, and added 2 drops of retarder to it (the instructions said one drop per ounce but I slipped :)). Before the retarder that paint was dry about 10 seconds after it hit the surface. With the retarder it took about 5 minutes to dry to the touch.
I also tried it with some paint I was trying to hand brush. I had a few drops of paint in an old paint cap, and the surface was drying in the cap in between loading the brush. Virtually unusable like that. Added a drop of retarder and it fixed it right up.
I like it!
- Member since
Posted by MikeV
on Wednesday, March 31, 2004 9:49 PM
Scott,
That sounds great. Keep us informed to any other things you find such as whether tip dry is eliminated somewhat.
- Member since
January 2004
Posted by MusicCity
on Thursday, April 1, 2004 7:59 PM
QUOTE: That sounds great. Keep us informed to any other things you find such as whether tip dry is eliminated somewhat.
Hmm .. I didn't think about the tip dry thing. As I've mentioned before, I just automatically wipe the tip off when I put the airbrush down so I didn't really notice. Now that you mention it though, I don't think there was as much paint on the Q-Tips though.
More great sites from Kalmbach Media
