Oil weathering - is Dullcote enough to protect acrylic
    September 2016
Posted by ManCityFan on Sunday, July 16, 2017 7:55 AM
I plan to use oil paints on a T-34 I am starting.  On my last tank, I only clear gloss coated where the decals went, then used Testor's Dullcote in the rattle can over the whole model.  I did not use oils on that tank.
Will this be enough to protect the acrylic paint underneath, or should I gloss coat the entire model before Dullcote?  I use odorless mineral spirits (Mona Lisa) to thin the oils.
Thanks,
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
Posted by Bish on Sunday, July 16, 2017 8:06 AM
You don't need anything to protect Acrylic paints from oil washes.
    September 2016
Posted by ManCityFan on Sunday, July 16, 2017 10:18 AM
Bish
Well, that is good to know.  One less thing to worry about.
Thanks Bish,
D
    September 2012
Posted by GMorrison on Sunday, July 16, 2017 11:32 AM
I sort of disagree. While you don't need it, having a clear finish allows idiots like me to wipe off poor applications and try again.
But if I go rubbing at wash over a base coat, I'll lose the base coat too.
It's always a good idea to experiment on a crap model. I have a few of those around. My usual method is to use turpenoid based washes over an acrylic clear coat.
    September 2016
Posted by ManCityFan on Sunday, July 16, 2017 1:01 PM
GMorrison
That is a good point.  I have a tendency to "mess things up", and will undoubtedly have to rub off some of the wash.  No harm in adding the gloss coat, just an extra step.
D
    July 2013
Posted by modelmaker66 on Monday, July 17, 2017 12:37 AM
Also without a clearcoat the oils may stain the paint and not wash down properly.
    July 2004
Posted by stikpusher on Monday, July 17, 2017 2:08 AM
A gloss coat allows the washes to flow more easily. But it will not allow for any "dot filters" as those alter the base color best over a flat coat.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August 2012
Posted by JMorgan on Wednesday, August 16, 2017 2:05 AM
I have found that using a weak thinner like Mona Lisa will not take off even an enamel base coat. While some pigment may show up on the rag when you wipe off the wash, it is minimal.
