First usage I had paint dripping from the end, figured it was the needle seating, adjusted as required, all is well.
But when I tried to spray, I managed to get a fine line for about 30mm, and then it stopped.
Cleaned the tip, got around 50mm of spray length, stopped again.
I use Tamiya and Gunze Acrylics mostly, and allowing for the dry time I adjusted my air pressure both upwards and downwards, from 5 psi to 40 psi, not all at once, but testing at different intervals, not a lick of difference did it make.
I'm stumped as to whats going on, and dare I say it, with my Aztek 470, I never had tip dry, so naturally if there is a simple solution to this problem, I do not know it.
Mind you, the fine lines I did get blew me away, I glanced over to the Aztek, frowned, and put it on the shelf for my brother to practice with.
The above is from the previous Tip Dry post. As for the mix, I tried from 50/50, through to 80/20 paint/thinner ratio. I use a syringe to measure my paints, so it was all pretty spot on.
The paints I'm using are flats, but that shouldn't make that much of a difference.
Yes Mike, the weather here is dry, but last 2 days have been pretty humid, so I gave the brush another whirl, and after polishing the needle and nozzle, it kinda improved things a bit, but still not where it should be for this quality brush.
Gonna try some different types of lubricant on the needle tip to see what happens, right now I'm plucking ideas from the air, but neccesity is the mother of invention after all.
Who knows, might come up with something to eleminate tip dry forever
