Looking for a large needle airbrush
    June 2017
Posted by Mars on Wednesday, July 26, 2017 8:51 PM
Im looking for an airbrush with a large spray pattern. I have seen a Badger 20/20 2-h with a .7 needle/nozzle. Has anyone used this airbrush and how do you like it? Does it give a wide spray pattern? Do you know of other brushes with wide patterns? Is there a brush that has medium and large heads in the same brush?
    October 2008
Posted by Don Wheeler on Wednesday, July 26, 2017 9:53 PM
The Paasche VL and The Badger 175 have a 1.0mm nozzle option.  And the Paasche Talon has a .66mm nozzle with a fan cap that gives pretty wide coverage.  The Badger 20/20 Sotar can use a .7mm nozzle, but it has an awfully small cup for such a large size.
How large a pattern do you need?
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    July 2013
Posted by modelmaker66 on Wednesday, July 26, 2017 11:56 PM
Don is absolutely right as usual. I have had a Sotar 20/20 in the past and the cup is too small, so don't consider it. His suggestions are perfect. I would thnk the Badger 175 is just right. I have a Badger Patriot 105 with a .7 setup and it is all I need for wide coverage. What are you painting that needs the coverage?
    June 2017
Posted by Mars on Thursday, July 27, 2017 12:26 AM
Don Wheeler
Don
Well, Im about to paint a 1/72 B-52. I think at least an inch or an inch and a half. I'm to the point that I want a quality gun but I can only buy one so I need one that can give small and large patterns. Is the .7 needle set available separately for the Sotar 20/20?
    December 2013
Posted by route62 on Thursday, July 27, 2017 7:47 AM
I have a grex tritium with a .2 and .3 needle with a fan spray attachment.  It ran me about 300 with all the extra needles, larger cup and fan spray.  It can go up to .5 needle.
It comes with three cups but you can purchase a 50ml and a 125ml cup which is 4oz, giant in the modeling world.
With the .2 needle I can get almost iwata micron fine lines and with the .3 and fan spray nozzle I get a 3 inch fan spray pattern, plenty for what you are doing.  They also sell a fan nozzle for the .5 needle.
Being a gun trigger style grip double action airbrush, it very easy to use and for longer painting sessions my hand does not fatique as quickly and I can use this gun both left and right hand and still have good control since it's a trigger grip.
    October 2008
Posted by Don Wheeler on Thursday, July 27, 2017 10:49 AM
You might want to check out Paul Budzik's video on this.  My personal opinion, based on work I have seen, is that large area coverage can be done well with a standard medium nozzle airbrush. But Paul makes a good point.
Don
    July 2013
Posted by modelmaker66 on Friday, July 28, 2017 1:07 AM
What is the intreat in a sotar may I ask?  Do you have one already? They are pricey and if you are not using it for detail work the refinements of the Sotar will be lost on larger paint areas. There are may better choices for wide area spraying. For deatil it is one of the best.
    June 2017
Posted by Mars on Friday, July 28, 2017 8:48 AM
Thanks for the info
Posted by Wingman_kz on Friday, July 28, 2017 10:23 AM
I have a Badger 175. You can buy it in a kit that comes with fine, medium and heavy needles, tips and caps. I don't use it that often any more but it is a fine airbrush. You can use it for fairly fine work as well as broad coverage and with a large bottle or two you could spray forever. Or, you could use the cup adapter and use it as a gravity feed with just a little paint at a time. Tony
