I bought Model Master flat and gloss clear online. The ad said it was enamel clear but when I got it it says laquer clear coat. Will Teastors enamel thinner work with this?
Do you have MM Clear Top Coat 2736? If so its clear enamel.
[quote user="mississippivol"]Probably not, but regular lacquer thinner should. Test for compatibility, though.
[/quote By regular laquer thinner, I assume it's what I can get at a hardware store?
plasticjunkie Do you have MM Clear Top Coat 2736? If so its clear enamel.
[quote user="Mars"]
[/quote]
Yes, sir.
Then use LT from Home Depot. That's what I use.
Thanks for the info
I also use MM clear flat....thinned about 50/50 with store brand lacquer thinner.
Istead of stending the money on their gloss...I bought a quart of Minwax clear gloss lacquer (again, thinned 50/50). The whole quart cost about the same as 2 MM bottles...I've done around 200 builds and have just passed the 1/2 way mark on that quart!
I just got done dullcoating a plane with the Testors dullcoat lacquer in bottle. I used lacquer thinner at 1:1, the same ratio I use with Testors enamel and enamel thinner. Worked fine.
