Quick question about air compressors
    February 2015
Posted by acctingman on Monday, August 21, 2017 12:00 PM
I have a cheap(ish) AC I bought from Harbor Freight Tools. It works great, but I have a noobish question.
I see some modelers with their AC running and then it shuts off. I'm assuming they have something on there that makes the AC turn off/on when it reaches a certain PSI they want, correct? Is this regulator?
Posted by Tojo72 on Monday, August 21, 2017 12:10 PM
Yes
    February 2015
Posted by acctingman on Monday, August 21, 2017 12:18 PM
Thank you!
I'm also guessing that any generic regulator will work with my AC?
    August 2014
Posted by goldhammer on Monday, August 21, 2017 12:49 PM
Go back to HF and get one of their adjustable pressure regulators with the gauge on it.  Then put one of their red "pumpkin" water trap filters on after that. Will run you under $10 for both.  Then you can use whatever adapter you need to hook in your airbrush hose.  Use the adjustable to tweak pressure to your needs.  I put the adjustable regulator on a quick disconnect so I can use it at the shop where I work, as well as on the compressor at home(3 gal pancake HF).  I can even hook a 25 foot regular hose and disconnect to it and keep the compressor on the porch and use the AB inside.
Compressors turn on and off due to the pressure switch on the compressor, they have a low and high limit setting.  You will also have a safety valve "pop-off" that keeps the thing from building too much pressure in the event the pressure switch goes outhose mouse.  Talking about regular compressors now, not the little AB types.
