Enamel paint and lacquer thinner
    September 2003
Posted by out04 on Monday, October 9, 2017 6:34 PM
I know some people swear that they have no problems using lacquer thinner to airbrush enamels, but when I try it the pigments separate from the liquid.  Any tips other than switch to enamel thinner/acrylics??
    January 2009
Posted by fermis on Monday, October 9, 2017 7:25 PM
I used a lacquer thinner with enamels (Model Master) once...in a pinch, ran out of Testors thinner. I can not remember the brand to save my life...but it worked very well. I tried again with some generic store brand, and pretty much got the same results as you...guess they're not all created equal!
So, I make sure not to run out of Testors enamel thinner (big red container).
    May 2017
Posted by bugman9317 on Monday, October 9, 2017 7:36 PM
I use Sunnyside lacquer thinner with Model Masters enamel mixed 2 to 1 paint/ thinner and can say you will get a show quality finish from it. I have been doing Don Yosts method of doing nice thin coats building it up where you end up with a nice final wet coat and it comes out amazing. My local Walmart has it in stock but you can get it shipped online.
https://www.walmart.com/ip/Sunnyside-Lacquer-Thinner/118499640
Posted by Don Stauffer on Tuesday, October 10, 2017 9:20 AM
I have also had bad results sometimes using lacquer thinner with Testors enamels.  I have stopped trying.
However, you can use good quality turpentine or mineral spirits.  There was a shortage of Testors thinner a couple of years ago and I started trying hardware store thinners.  I already had some on hand for cleaning brushes and airbrush. There is some real junk just labeled paint thinner being sold at stores.  As long as I make sure the can or bottle says either mineral spirits or turpentine I have had no problems.
    November 2008
Posted by plasticjunkie on Tuesday, October 10, 2017 10:13 AM
I get excellent results thinning MM enamels with the Testor's red can thinner from HL. I do use LT from Home Depot to clean the AB.
 GIFMaker.org_jy_Ayj_O
    September 2012
Posted by GMorrison on Tuesday, October 10, 2017 10:22 AM
Red can all the way and it lasts a long time.
Most "lacquer thinner" is not thinner at all. It's clean-up solvent. It isn't what an auto body shop would use to thin paint.
    September 2003
Posted by out04 on Tuesday, October 10, 2017 4:30 PM
I just tried mineral spirits (Klean Strip) like mentioned above and other than the smell I can't tell a difference from the red can Testor's thinner, worked very well.
    November 2008
Posted by plasticjunkie on Tuesday, October 10, 2017 6:32 PM
Try making a wash with the Klean Strip. It will look ok till it goes on and the paint in the wash separates like coffee grounds. That's the reason I switched to the red can.
