Just so you know: The motor you are using was never ment for continuous use.( it will probably burn out at a most "inopertune" moment.)
Seth Krumm
I happen to have a blower used for an inflattable water slide lying around.
Unless you are talking about the kind that are used for those "bouncy house's" .... like you would rent for you're kid's birthday.
In any case, you will probably never pump enough paint through a fan to cause a "major" explosion. A small fire .....maybe. (but not very likely) Only if the fan has a defect. But unless you're airbrush has a 5 gal. cup i wouldnt worry about it. ( By all means keep a fire extinguisher handy..... I have been wrong ..... from time to time.)
