Brushes not being cleaned
    March 2015
Posted by Peaches on Sunday, October 15, 2017 4:01 PM
Ok, I am going to beat a dead horse here, but I am having a problem with my brushes not cleaning.  I am using the Mona Lisa paint thinner from HL, and I go to clean it after using it, and it still has flakes of paint on the brush.  I have thought about switching to turpentine to try and clean it.  Any suggestions?
WIP:
Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
    July 2008
Posted by jeffpez on Sunday, October 15, 2017 4:15 PM
Use cheap lacquer thinner for cleaning and save the Mona Lisa for thinning.
    July 2013
Posted by modelmaker66 on Monday, October 16, 2017 12:53 AM
jeffpez
Absolutely! LT cleans everything!
    September 2012
Posted by GMorrison on Monday, October 16, 2017 2:50 AM
Yep. It also makes brushes last about 1 year, at most.
Clean your brushes following acrylics with hot water.
Clean your brushes following Testors enamel with LT but really keep it a quick operation.
Clean your brushes after using oils with Turpenoid.
When I write Icons, I use acrylics mostly and I clean them with water, spit shape them and then give them a little prayer before I set them down.
If you get to know your brushes by sight and by their temper, it will do wonders.
Sounds stupid? Maybe but they serve you well if you keep the solvent exposure to a minimum.
    July 2013
Posted by modelmaker66 on Monday, October 16, 2017 2:10 PM
GMorrison
That is a good point. Keep the time to a minium in the solvent. When you are done with the LT you can use masters brush soap on the brush to help clean the solvent out and condition the brush to last longer. You can get it at craft stores and amazon. It's  cheap and does preserve brushes and will clean acrylics great. I forgot about it when I replied the first time but GMorrisons' reply reminded me of it.
    March 2015
Posted by Peaches on Wednesday, October 18, 2017 12:25 AM
I actually went to the dollar store and picked up a cheapo bar of soap for basically the same thing.
WIP:
Academy F-18 (1/72)
On Deck
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Posted by Don Stauffer on Thursday, October 19, 2017 8:54 AM
Be careful cleaning brushes with lacquer thinner.  Some brushes sold just for acrylic paint use synthetic fiber, and some of that stuff dissolves in lacquer thinner.  These brushes may say "for acrylic use only."
