Replacement paint for WW2 Japanese aircraft
    September 2011
Posted by falconmod on Wednesday, November 8, 2017 1:53 PM
So now that Testers in it's infinite wisdom is discontinuing the Model Master enamel line does anyone know what paint I can use to replace the navy and army greens and grays for WW2 Japanese aircraft?
  That I can use in a air brush and I can get in the states.
Thanks
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, November 8, 2017 2:25 PM
MM acrylics. Sorry to say this but acrylics are what's going to be left be it Life Color, Vallejo, Model Master, Tamiya.
Order online in places like scalehobbyist and stock up a few bottle of each color you need.
Sending you a PM on a LHS in my area you could try since he has quite a lot of Model Master enamel paints in stock.
    April 2009
Posted by Cadet Chuck on Wednesday, November 8, 2017 7:47 PM
    March 2010
Posted by ACESES5 on Sunday, November 26, 2017 8:32 PM
Hang in there Chuck Tamiya in going to bring there lacquer paints into the U.S. they should have the Japanese colors you need.Bow Down                 ACESES5
    July 2004
Posted by stikpusher on Sunday, November 26, 2017 9:48 PM
Humbrol has made no indication of discontinuing their enamels line, or shipping it to us here in the colonies... Mind you that they no longer have their dedicated Japanese colors of their old “Authentic” line. But they have several that will work as close substitutes in most cases.
But if you’re gonna go acrylic, I’d say go Tamiya as they airbrush wonderfully, and they have dedicated Japanese colors.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, November 26, 2017 10:28 PM
ACESES5
They don't have a wide range of colors in their lacquer lines. I'm with stik on this one - Tamiya acrylics is your best choice.
    May 2011
Posted by Real G on Monday, November 27, 2017 2:01 AM
John,
Gunze Mr. Color lacquers are available now in the US.  They have an extensive line of WW II Japanese Army and Navy A/C colors; greens, greys, propeller brown, cowling black, interior colors representing Mitsubishi & Nakajima factory built planes, and maybe others.  Now I have ZERO (pun intended!) idea if the colors are regarded as accurate, but they do look good.
If your LHS or favorite mail order shop stocks Gunze paint, you are all set up.  HTH
“Ya ya ya, unicorn papoi!”
    July 2004
Posted by stikpusher on Monday, November 27, 2017 12:02 PM
Although Gunze has a slightly larger selection of Japanese aircraft colors compared to Tamiya, I would still recommend Tamiya. One, Tamiya acrylics are easier to work with. Two, Tamiya paints are thinned with their own thinner, isopropyl alcohol, or generic lacquer thinner. And three, with their retarder, Tamiya paints are now easily hand brushed again. At least like they used to be when first introduced and before they were reformulated.
Gunze Mr Color paints are much harder to find in a shop. They thin only with their thinner (which is very pricey), or lacquer thinner (fairly at best), and do not hand brush as well. At least I have not yet found the trick to do so yet....
Tamiyas line of Japanese aircraft paint colors has a few more than the Model Master line.
So there are the pros and cons between the two replacements that I have found.
       - Plankton
LSM
    September 2011
Posted by falconmod on Monday, November 27, 2017 12:21 PM
So you can really use lacquer thinner with thier acrylics?
John
    July 2004
Posted by stikpusher on Monday, November 27, 2017 1:10 PM
falconmod
John
I have used hardware store lacquer thinner with both Tamiya acrylics and Gunze Mr Color paints for airbrushing. It works with both types, but I think it worked better with Tamiya.
Lacquer thinner and Mr Color is more sensitive to the mix ratios. If the ratio is off, the paint can “spider web” or come out like cotton candy as it is moving in between your airbrush and model.
       - Plankton
LSM
