How To erase Sand Marks[?]
    July 2003
Posted by KJ200 on Wednesday, March 31, 2004 6:30 AM
Try a nail buffing stick.
As these usually come with 2 or 3 different grades of abrasive, start with the coursest first, and as the scratches become less noticeable, switch to the next finer grade.
It's just like MikeV said, just all on a stick!
I find I can polish the plastic back to a perfect shine using these, and they are way cheaper than the sanding sticks most hobby shops sell.
I don't have a coffe filter at home, would instant work?Big Smile [:D]
Karl
Posted by MikeV on Monday, March 29, 2004 11:10 PM
QUOTE: Originally posted by Kolja94
They're not supposed to be used ones, are they? Clown [:o)]
That may work for a wash or stains on the aircraft. Laugh [(-D]Smile,Wink, & Grin [swg]
Posted by Kolja94 on Monday, March 29, 2004 11:07 PM
Karl
Posted by MikeV on Monday, March 29, 2004 8:11 PM
QUOTE: Originally posted by monrad
Coffee filters??? I have plenty of those. I will give it a try.....Thanks for the tip. Thumbs Up [tup]
You are welcome, but give the credit to Pixilater as it is he that I learned it from. Big Smile [:D]Wink [;)]
Thanks Pix. Cool [8D]
Posted by Anonymous on Monday, March 29, 2004 7:45 AM
Posted by MikeV on Sunday, March 28, 2004 11:23 PM
QUOTE: Originally posted by Enzo_Man
Use coffee filter 'eh. Hmmm... I'll have to try that.
It works great. I was sceptical until I tried it, but it does work very well.
    December 2003
Posted by Enzo_Man on Sunday, March 28, 2004 11:21 PM
Aerodynamics is for people who can't build engines.
Posted by MikeV on Sunday, March 28, 2004 4:07 PM
Using progressively finer sandpaper will eliminate them.
I usually start with 320 wet and then use 400 wet and then 600 wet if necessary. The primer will hide the small scratches that are not very deep.
Another trick that I learned from someone on this forum is to rub the area with a paper coffee filter after sanding as the fibers in the coffee filter will shine the plastic up real nice.
Posted by Anonymous on Sunday, March 28, 2004 3:42 PM
Whats the best method to erase the ugly sanding marks (deep and shallow)Question [?]
Will the layers of primer, paint, and finishes fill the gaps and make the sanding unnoticableQuestion [?]
