paper masking
    March 2016
paper masking
Posted by ardvark002 on Friday, December 15, 2017 9:02 PM
Hi all, Just wanted to pick some brains.How many use wet paper mask? I used it once from a kit it came with and it worked well. I have some tight cerves to do and figuer that I can cut them easier on paper than tape. Also I can duplicate port to starboard. I know that you an get some, but I want to learn to make my own. Any sites or help would be greatfully recieved. Thank you and keep on building,  Aardvark        On the bench:  1/48 Testors Lear 24 & Hasagawa P-51D
Posted by Don Stauffer on Saturday, December 16, 2017 9:47 AM
I use tissue paper a lot for inside cockpits when I am painting before mounting canopies.  I stuff (carefully) the tissue into the cockpit, then wet the surface so it stays in place and does not shed.
I use unwet paper for masking a lot. If I want a mask to cling to the surface of the model, I use plastic wrap.  I use tape along the demarkation line, then the plastic wrap over larger areas to save masking tape.  I tape the plastic to the masking tape along the demarkation line.
