Something is wrong. The Patriot shouldn't do that. Before you buy another airbrush, try spraying some ink or food colors and see if you have the same problem. If it goes away, maybe it's the way you thin your paint.
You don't mention your air source. With really thin paint, 10 or 15psi should be enough. thicker paint requires more air pressure.
If it still does it, you might want to send it to Badger for an overhaul. They will only charge for parts if needed. The Iwatas are fine airbrushes, but you should be able to do a pencil-like line with the Patriot.
Don
