Model Master Metallics paint sequence
    June 2017
Posted by UnwaryPaladin on Friday, February 23, 2018 4:41 PM
Hi, I needed something to fiddle with and started building a 1/72 Hasegawq Ki43 Oscar. Great little kit! I'd like to try the Model Master Metalic (buffable), but I'm not sure about the paint sequence. The airplane has an anti-glare black/blue coat and the yellow ID markings on the leading edge of the wings. Should I paint the colors first, mask, then do the metal or paint the metal, seal, then colors? I have the recommended sealer.
Posted by Tojo72 on Friday, February 23, 2018 4:46 PM
I would try to avoid masking the metalizer with tape if you can,it's pretty delicate stuff.I have masked it with post-its.
    April 2009
Posted by Cadet Chuck on Friday, February 23, 2018 8:26 PM
Important note:  Do not use primer.  The metallizer is designed to be applied to bare plastic, for best results.
Tojo72 is right, it is very delicate and easy to pull off with masking tape.  Post-its are a good idea, if you can't avoid masking.  I would try to use colored decal strips cut to fit, to avoid any masking.
    November 2003
Posted by mississippivol on Friday, February 23, 2018 8:54 PM
I paint the antiglare and leading edges first, masking off any thing that will be covered in metalizer later. Then I mask those areas and paint the metalizer. Probably why I've done only one nmf bird. If you don't seal it, use cotton gloves and try to limit handling it so you don't smear metalizer on places that you don't want it.
    June 2017
Posted by UnwaryPaladin on Friday, February 23, 2018 10:12 PM
Thanks for the replies. I've heard it's a delicate paint. I picked the paint and sealer up when I first got back into modeling, before doing much research on it. I'm reluctant to try it!
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, February 24, 2018 8:47 AM
Get Alclad instead. No sealer needed.
    March 2015
Posted by JohnnyK on Sunday, February 25, 2018 4:33 PM
Cadet Chuck
I agree with Chuck, never use primer. If you use primer first the Metallic paint will have a rough finish. I use a paper stump to buff the Metallic paint prior to sealer. Once the paint is buffed it will no longer come off on your fingers. After the paint is sealed it is not too delicate. I do use masking tape, but first I press it to my forehead to remove some of the stickyness.
This is the wing of a B-24. It is painted with Testors' Metallic Aluminum. It has been buffed and sealed.
This is the wing with blue masking tape. I painted the unmasked areas with Testors' Metallic Stainless Steel.
This is the wing after the masking tape was removed. Notice that the masking tape did not "lift" the Metallic Aluminum paint.
    January 2017
Posted by mawright20 on Monday, February 26, 2018 2:33 AM
Great tutorial!
    June 2017
Posted by UnwaryPaladin on Monday, February 26, 2018 1:26 PM
JohnnyK, that looks great! Thanks for posting
