Before starting a build, most everyone will wash all the sprues and parts with warm soapy water (dish soap) and rinse well, let air dry. Sounds like you still have some mold release on the parts, washing will get rid of it.
I personally will lightly scuff everything with a fine (gray) auto paint scotchbrite pad. If I prime, I'll finish scuff with the same again prior to color.
I use about the same ratio, seems to work for me, others will use different mixing ratios and different paints.
Haven't had an issue with paint peeling off when masking for other colors, either primed or not with either Tamiya or Model Master acrylics. I will prime more just to cover filler and check for acceptable filler, low spots, visable seams, etc., and have one color to have to cover rather that a couple of varying colors that may take more coats, depending on the color.
Once you get the paint to your liking, spray a coat of gloss clear overall, then decal. If you are going to weather, do it now, then you can give it a coat or two of flat clear to seal everything and give it the flat look of a warbird.
