Wilbur, you may have already tried this, if you slow down your paint passes and are close enough, you'll have a wetter paint mix laying down. You can actually get by with quite a lot of that, and not have the risk of runs.
While I rarely use them, products that affect the consistency of sprayed paint can be a help in some cases. Liquitex makes two, Flo Aid and Slow Dri, both can be rather touchy to use. Flo Aid is to be mixed 20:1 with water then added to acrylic paint, and their instructions say use sparingly. They are not kidding, but it has it's place when needed.
Slo Dri is a different matter, it is added as a surfactant to simply slow the drying process, I think maybe better for using a paint brush. Must allow two or three days drying time before further work, like decals or clear coat. I have airbrushed with it but didn't seem useful to me.
The 200NH has a fairly generous needle/nozzle size, so it should be capable of laying down a wet mix. I use about 15psi with mine. Hope you get it sorted.
Patrick
