Airbrush Hygiene Questions
    April 2018
Posted by Oxboy on Tuesday, May 1, 2018 4:58 PM
Gentlemen,
My first airbrush is on the way.  Therefore I have a very basic question that all the airbrush videos I've seen haven't really answered:
You don't take it apart and clean it after every paint change do you?
If not, how many paint changes to you go before the whole breakdown and clean?
Or do you breakdown and clean between projects?  Once a month?  Do you clean it every 3 mos regardless if you use it or not?
If you are building a kit that involves 10 different airbrush sessions with 10 different paints/lacquers/whatever, do you just clean the can 10x and then breakdown the whole thing when all done?
Thanks for all the advice, oldtimers. Big Smile
    August 2014
Posted by goldhammer on Tuesday, May 1, 2018 5:14 PM
With my NEO, I'll flush and back flush between color changes, and when done for the day, give it a good cleanout.
Not totally kosher according to some, but have yet to tear it completely down.  Usually pull the air cap and nozzle cap on the final cleaning, gently wipe the needle and really clean out the nozzle tip, then run a little acrylic cleaner through.  I only use acrylics though, so your MPG may vary depending on your AB and what you decide to spray.
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, May 1, 2018 5:18 PM
I break it down and clean it after every use. I usually flush and back flush thoroughly between color sessions.
    September 2012
Posted by GMorrison on Tuesday, May 1, 2018 5:22 PM
I spray thinner through it, backflush and wipe clean between colors, without disassembly.
Usually after a session, I just do that again, then pull the needle and wipe it off thoroughly.
Taking it all apart is something I try to avoid, because among other things you can lose parts.
Posted by keavdog on Tuesday, May 1, 2018 5:23 PM
I flush and back flush with lacquer thinner.  And change the tip periodically. $10 for my passche
I change it mostly when I drop it or ding the tip
Thanks,
John
    April 2018
Posted by Oxboy on Tuesday, May 1, 2018 5:42 PM
So a "use" can be made up of several color sessions?
    August 2014
Posted by goldhammer on Tuesday, May 1, 2018 6:10 PM
Oxboy
I suspect by color sessions he means spraying different colors at the same sitting, and when done then he'll do the tear down.
By flushing we generally mean cleaning out the bowl on gravity feeds or putting a bottle of thinner/cleaner on the siphion feeds, and spraying till clear.  Back flush is putting a finger over the nozzle and hitting the trigger to force air back into the cup, then spray a little more till clear.  Then go onto the next color.  When all done do the thorough cleaning.
    May 2013
Posted by Greg on Tuesday, May 1, 2018 8:03 PM
Me too. And to clarify, for me that means at the end of the day a breakdown and complete clean. Whenever I've forgotten, things are never right next time I use the a/b.
A clean airbrush will lead to a happier you.
    February 2010
Posted by Stage_Left on Tuesday, May 1, 2018 9:01 PM
Just to pile on, here's some advice I follow. Enjoy your new toy!
Dave
    July 2013
Posted by modelmaker66 on Wednesday, May 2, 2018 12:56 AM
Stage_Left
Dave
Excellent tutorial Dave!
Posted by Don Stauffer on Wednesday, May 2, 2018 9:31 AM
I do not disassemble between paint changes, just run thinner through until no color comes out.  For simple kits I sometimes finish the kit before disassembly and clean.  For longer projects I have learned to tell when it needs the thorough cleaning.  One telltale to me is when you can see paint on nozzle surface after the flush with thinner cleaning.
An intermediate cleaning beyond flushing with thinner is to remove and clean the needle.
    December 2017
Posted by drumsfield on Wednesday, May 2, 2018 11:05 AM
Stage_Left
Dave
I do everything he says. I use Rustoleum Laquer thinner (about $14 a gallon from walmart) for cleaning. Occasionally I'll use CVS IPO depending on the paint.
Although I do wipe down the needle and maybe add a little oil after I'm done for the day. I've had instances where I'd get chunks of old paint splatter on my work, I'd like to avoid that if possible.
