ALCLAD II BLACK PRIMER & MICROFILLER ALC 309
    February 2017
Posted by Tubosteve on Tuesday, August 14, 2018 3:39 PM
Hi All,
Going to be starting a P-51D Mustang soon with NMF. want to challenge myself with something new and never tried NMF before.
Looking at using Alclad for the NMF but never used it before. A quick look at the Alclad website shows they recommend using Alclad II Black primer & microfiller (ALC309) but have seen that many use a black gloss as a base.
Do I need to use the ALclad primer or can I just go for a black gloss?
What way do most of you more seasoned modellers use?
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
Posted by Bish on Tuesday, August 14, 2018 3:49 PM
Useing a gloss base is only needed for their high shine finishes, but some people do use it for their regular finishes. I use Alclad Black primer all the time, and i really like it. But you don't have to use it, but it does give a great finish.
    September 2012
Posted by GMorrison on Tuesday, August 14, 2018 4:03 PM
I've had good results with gloss black enamel. I think I had a bad bottle of Alclad Black
    September 2017
Posted by Sailing_Dutchman on Tuesday, August 14, 2018 4:04 PM
I prefer to use Alclad grey primer and microfiller (my goto primer) and then overcoating it with Alclad aqua gloss.
Posted by Don Stauffer on Wednesday, August 15, 2018 8:28 AM
I have used many different undercoats.  The Alclad primer is my least favorite.  My goto is Testors gloss black enamel.  I found automotive lacquers work fine.
I have also used colored undercoats if I wanted to tint the Alclad. I have successfully use both blue and yellow to create tinted alloy looks.
    June 2017
Posted by fotofrank on Wednesday, August 15, 2018 2:31 PM
I agree with Don. I have better success with a gloss black enamel under Alclad. I have used Alclad's black primer but I have found the surface to be rather rough and have had to buff the surface with an 8000 grit micro fiber pad before applying color. I haven't tried a flat black enamel yet but I'd think it would work well too.
OK. In the stash: Way too much to build in one lifetime...
    November 2008
Posted by plasticjunkie on Wednesday, August 15, 2018 4:55 PM
I use black gloss enamel in the small Teators bottle heavily deluted to get a glass smooth finish for the high shine Alclad shades. The trick is not to completely cover the black enamel. Leaving a hint peeking thru will give the Alclad depth and a realistic metallic finish.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Thursday, August 16, 2018 8:29 AM
plasticjunkie
I agree.  I control the level of sheen by controlling the thickness of the Alclad.  I dial the paint flow way back, and lay it on gradually until I get full coverage but that polished look. It is easy to go too far, and then it looks less polished.  In fact, I sometimes vary panel look by masking off first, highly polilshed coat by letting it dry a few minutes, then masking panels with Post-it note papers, applying the same polilshed aluminum, but build it up thicker, and thicker yet on some panels.
    August 2013
Posted by Jay Jay on Thursday, August 16, 2018 9:35 AM
I use Mr. Color GX 2 gloss black overcoated with their K2 clear as a base. No sanding required. This combination does wonders for a good shiny aluminum finish and lets you cover the black well so none shines through. The final NMF has no grainy appearance to it viewed up close like it would with sparsely coating the Alclad.
Check out Will Pattisons' vid on youtube
ep180b - the chrome showdown, part 2
