Spraying future over removable parts
    June 2018
Posted by model lover on Saturday, August 25, 2018 7:04 AM
I'm building a model with removable parts, will airbrushing future over them while they are connected to the model cause them to stick to it. Or will there be no problem.
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, August 25, 2018 9:01 AM
To be safe, I’d spray each removable part separately.
Posted by Bish on Saturday, August 25, 2018 9:37 AM
Ditto While the parts may well come away, you might well have a raised edge.
    June 2018
Posted by model lover on Saturday, August 25, 2018 10:27 AM
What do you mean a raised edge.
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, August 25, 2018 5:07 PM
model lover
Meaning if you sprayed with removable parts on the model, after it dries, any attempt to separate your removable parts will be stuck together, thus causing a raised edge.
Thats why it’s best to spray them separately.
    September 2012
Posted by GMorrison on Saturday, August 25, 2018 5:13 PM
And, all that acrylic which formed the "raised edge"; didn't go where it was supposed to go. There'll be bare spots. Future is thin, and if you do need to remove it, go at it with a q-tip dipped in Windex (ammonia).
