True North Precision Paints
    August 2013
Posted by Straycat1911 on Saturday, October 27, 2018 4:17 PM
I was poking around for a source for ADC Gray and I found THIS:
https://www.truenorthpaints.com/paintshop
Tags: ADC Gray
    July 2004
Posted by stikpusher on Saturday, October 27, 2018 4:32 PM
Very nice! A new enamel paint line! And with a great color selection... thank you for the heads up!!!!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, October 27, 2018 5:43 PM
stikpusher
Oh yeah... I see a couple colors I could use.
    July 2004
Posted by stikpusher on Saturday, October 27, 2018 5:45 PM
stikpusher
More than a couple for me, my friend... and being enamels that means no worries about new thinners, flow enhancers, etc.
       - Plankton
LSM
    August 2013
Posted by Straycat1911 on Saturday, October 27, 2018 6:09 PM
Quite welcome. First I’d ever heard of them.
    August 2013
Posted by Straycat1911 on Monday, November 12, 2018 6:20 PM
So being a airbrush rookie, I could use some advice on thinning enamel paints. Specifically ratios and what thinner to use.
I have on hand KleanStrip Paint Thinner; would that work or is there a better alternative?
    January 2013
Posted by BlackSheepTwoOneFour on Monday, November 12, 2018 7:31 PM
Since you're an aairbrush rookie, I highly suggest you start with the brand thinner to the brand paint you're using first before trying other alternative. ie: Testors enamel. use Tesors brand thinner, Humbrol enamel, use Humbrol brand thinner, etc... Different thinners of different brands can react differently - both good, bad, and the unknown.
Paint to thinner ratio should be experimented on your own. If it's too thick add thinner, if it's too thin add paint. Basically, you want the paint to be the consistency of skim milk.
Once you figure out the ratio and gain a bit of experience airbrushing, then try alternative thinners.
    March 2014
Posted by BarrettDuke on Monday, November 12, 2018 7:46 PM
Stray, I second BlackSheep on that. I haven't used enamels in a long time, but I can tell you that acrylics are really particular about what you add to them. Enamels are probably not as sensitive, but if you're just getting started, you're going to have enough things driving you crazy as you figure out airbrushing. No sense in adding another variable until you've worked out other things. If you use the paint maufacturer's brand of thinner, then you can rule out thinner problems as you're learning. Barrett
    July 2004
Posted by stikpusher on Monday, November 12, 2018 9:34 PM
I use the Testors universal enamel thinner with all my different enamel brand paints (Testors, Pactra, Xtracolor, Humbrol, Aeromaster, Revell, etc.) and have zero problems. But I use that only for airbrushing. For cleaning both brushes and my airbrush of enamel paints I use generic hardware store paint thinner and lacquer thinner.
       - Plankton
LSM
Posted by keavdog on Monday, November 12, 2018 10:14 PM
Thanks for the link.  I ordered a few different paints.
I thin enamels with lacquer thinner 50/50 for testors.  I'll have to see what these paints look like.  The general guide is to thin to milk consistancy.
Thanks,
John
    August 2013
Posted by Straycat1911 on Monday, November 12, 2018 10:14 PM
Guess I’ll have to check with True North to see if they have a brand specific thinner on their page. They’re the enamels I was referring to.
Stik, that’s another option I will try. Thanks much, guys.
Edit: apparently they do have their own thinner but also claim any enamel thinner will work on their paints.
https://www.truenorthpaints.com/paintshop/enamel-thinner
Posted by Don Stauffer on Tuesday, November 13, 2018 9:11 AM
Straycat1911
I would stay away from any synthetic paint thinner.  These have a milky appearance, but they usually come in opaque containers, so you can't see that until you get it home.  They are junk.
I make sure they are real turpentine by looking for the either the word "turpentine" or the phrase "mineral spirits."
Also, if the manufacturer offers its own thinner, this is often the best bet, but can be more expensive than hardware/paint store thinner.
    August 2013
Posted by Straycat1911 on Tuesday, November 13, 2018 12:12 PM
Don Stauffer
Straycat1911
yup, the Klean Strip says mineral spirits on the label. But just to be sure, I picked up the Testors brand.
