boatdetective actually was asking about the Iwata and if it was a good choice, would he have to change paint to thinner ratio if he went this route. The answer is maybe on the paint ratio ( the Iwata being good or not is not in question), not because it's a certain Iwata but because depenging on the Krome he has and that needle set, it may be requiring extra thinning now. Some Kromes come with an extra fine needle, which I believe is a .21. If he has that needle set the paint would need to be very thin. I use a .25 on fine details now and then and I thin the paint quite a lot even at that. .25 in the Badger lineup is considered fine. x fine is finer.
Most model paints work best with .35-.5 needles as I mentioned already, I also thin and spray craft paints a lot and use the .5 for those. These are available for the Krome. To my knowledge the Krome uses the same needles and nozzles as the rest of the Patriot line.
But again, if he wants an Iwata there is nothing wrong with them.
