Tamiya X-19 Smoke
    July 2010
Tamiya X-19 Smoke
Posted by roony on Friday, March 22, 2019 12:24 PM
I was tinting the sun roof on a car.  I'm not a great airbrusher, but this was one of my poorer attempts.  I did mix it with X-20 thinner.  Is there a difference when spray the Tamiya clear paints?
    September 2012
Posted by GMorrison on Friday, March 22, 2019 1:22 PM
    July 2010
Posted by roony on Friday, March 22, 2019 10:12 PM
GMorrison
Thank you.  That is one zombie thread.  And back to the "where are they now" thread.
Posted by keavdog on Saturday, March 23, 2019 2:37 AM
I've only sprayed smoke for a couple purposes.  Exhaust trails on a Skyraider and post shading on bare metal aircraft.  I thin smoke just as I do with all Tamiya paints -50:50 with Isopropyl alcohol.
Here's the exhaust on the Skyraider applied with multiple coats
And a lighter touch for post shading on bare metal - still learning here
Thanks,
John
    July 2010
Posted by roony on Saturday, March 23, 2019 10:14 AM
keavdog
keavdog wrote the following post 7 hours ago: I've only sprayed smoke for a couple purposes. Exhaust trails on a Skyraider and post shading on bare metal aircraft. I thin smoke just as I do with all Tamiya paints -50:50 with Isopropyl alc
ohol.
It worked for you.  Very well, I might add.
    June 2004
Posted by TigerII on Saturday, March 23, 2019 3:19 PM
Hey keavdog, nice job on the airbrushing of Tamiya X-19 Smoke. I bought a bottle but have yet to use it, because before Tamiya came out with that, I used to mix a 50:50 mix of Flat Black & Flat Brown, and I still do. I called it 'Soot'. I also thin the 'Soot' with alcohol. It works very well and it all depends on the amount you are going to apply.
Achtung Panzer! Colonel General Heinz Guderian
    August 2005
Posted by Phil_H on Saturday, March 23, 2019 9:54 PM
roony
The transparent colours are meant to be used for tinting clear parts, but this can be a little tricky.
I'd suggest airbrushing it in thin layers, allowing each layer to dry before applying the next. If applied too heavily, surface tension will pull the paint towards the edges of the part, leaving a gradated appearance (ie will be darker around the edges.)
Now the problem is that when painting with gloss paints, which the transparent colours are, you need a decent wet coat to get a good gloss. Applying the tint coat in thin layers may not give you a good gloss.
What you can do i::
(a) hit it with a good coat of clear gloss after it's dry;
or
(b) apply the tint coat to the inside of the clear part and let the plastic itself provide the gloss. This is the same principle used for painting clear R/C and slot car bodies.
    September 2012
Posted by GMorrison on Saturday, March 23, 2019 11:00 PM
Obviously doesn't work for canopies- I put this kind of paint down over silver.
Here's Tamiya green. I did six coats to get this.
    July 2010
Posted by roony on Sunday, March 24, 2019 12:28 PM
Phil_H
What you can do i:: (a) hit it with a good coat of clear gloss after it's dry; or (b) apply the tint coat to the inside of the clear part and let the plastic itself provide the gloss. This is the same principle used for painting clear R/C and slot car bodies
Thanks for the tips.  I'll try putting a clear coat on.
    July 2010
Posted by roony on Sunday, March 24, 2019 12:32 PM
GMorrison
Silver first? or the green then silver to give shine?
