I just shot some of the Gunship Gray Acryl a while ago and it produced a smoother finish than the MM enamels that I usually use. I was really impressed.
I mix 50/50 water and isopropyl alcohol for my thinner and then mix that with the Acryl in a 2:1 ratio of paint to thinner. I sprayed it at 30 psi and it flowed nice.
What I have found though is that my acrylic airbrush cleaner I have mentioned before does not clean the Acryl paints from the walls of the airbrush color cup.
I have to use lacquer thinner to get it out. I don't know what Testors adds to this paint to make it adhere like it does but it sticks like glue.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
