I'm still having trouble with Washes.
    July 2003
Posted by ridleusmc on Tuesday, April 6, 2004 4:16 AM
Hey all,
I've been working on armor lately, and I've been having some issues with weathering, namely applying the wash. First I tried using acrylic paint mixed diluted in alot of water. That made streaky/bubble looking things. Then on advice from my local hobby shop recommended adding a drop of Dawn dish detergent to that mix. But my problem persisted. Then I tried to use Artist watercolors greatly diluted with a drop of dishwashing detergent. But the streaky/bubbly looking things persist, although they aren't as bad. Are there any ideas as to what I can do to apply a good wash to my tanks, so their recessed areas look a bit darker and grimier. Any help would be appreciated.
Thank ya'll
Chris
    July 2003
Posted by saltydog on Tuesday, April 6, 2004 6:44 AM
hello chris, my names chris.Wink [;)] i use artists oils for my wash. i buy them from walmart and thin them with mineral spirits. for tanks, the only colors your gonna use is basically black, white(mostly for tinting), raw umber, and burnt sienna. i mix mine in a little white plastic palette with 6 little spoon sized containers molded into it (from walmart as well). oils will settle to the bottom quickly so you must constantly stir when you load your brush. if youve used enamels to paint your model with, let it cure for atleast 24 hours, then apply a coat of future or clear gloss as this will protect your finish from the mineral spirits and be easier to wipe the excess wash from your model. this method has worked well for me everytime. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Tuesday, April 6, 2004 7:49 AM
you can also use isopropyl alcohol to thin acrylics but they will dry alot faster, I haven't tried it myself, but a friend of mine does it every time.
    December 2003
Posted by cbreeze on Tuesday, April 6, 2004 9:36 AM
Chris,
I just got back into modeling aflter about a 15 year lay off. Read a number of threads about weathering techniques, including washes. I found that most of the tips really work but have settled on a favorite. I use artist oils thinned with lighter fluid. You will only need black, wite and umber or burnt sienna. First spray your base coat. Then spray a gloss coat. Made sure you give each coat enough time to dry. After the gloss coat is dry, mix up your oils thinned with lighter fluid. the fluid evaporates fast so you will probably keep having to add more fluid. After you coat your piece, give it a few minutes then wipe the washed area with a clea paper towel or q-tip dipped in clear fluid. I like the wash/ligter fluid mix the best because it really flows well and drys quick.
BTW when you are satisfied with your wash, spray a flat coat and you are pretty much done. Practice on some scrap pieces before you apply the technique to your work in progress. This method is pretty much idiot proof.
Hope this helps.
Chuck
Posted by Anonymous on Tuesday, April 6, 2004 1:27 PM
Hi Chris,
I generally wash with artist's oils thinned with Humbrol brand enamel thinner, I find it just work better for me that way. I have used acrylics to good effect, but artist's tube acrylics, not hobby paint.
The problem you're getting is from using water as a medium. Used straight it has too much surface tension to flow properly. In theory the detergent should fix that, but it doesn't work for me either! I use 'Rubbing Alchohol' from the chemist (drugstore I guess Smile [:)]) as a medium for acrylic washes. Rubbing alchohol is 70% Isopropyl and gives the acrylic wash the same 'feel' as the oil washes I generally use.
Hang in there, you'll get it! Big Smile [:D]
    July 2003
Posted by ridleusmc on Wednesday, April 7, 2004 4:39 AM
Thank ya'll,
I'm going to do some more experimenting, but I'm pretty sure that I'm giving up on using water to thin the mix. I have some lighter fluid and acrylic thinner sitting around. Thank you all for your input.
Chris
Posted by maddafinga on Wednesday, April 7, 2004 8:23 AM
If you have a few bucks, give a water soluable oil paint a shot. Mix it with water and a little bit of vinegar and a bit of dish soap. It's slow drying and a relly finely ground pigment. It's basically the same as a regular oil paint, it just uses a modified linseed oil as a carrier instead of the regular stuff. I never had great luck with washes until I gave this stuff a try. Anyway, if you're in an art store one of these days and have 5 extra bucks, it might be worth grabbing a tube. They work great for dry brushing also.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
