Krylon Disaster
    January 2015
Krylon Disaster
Posted by Aggieman on Thursday, June 13, 2019 12:01 PM
Today is going just great.  First the daughter broke the screen on her iPhone, then I seem to have suffered a disaster on my current project related to the Krylon Gloss Black I was painting.
The kit is not a cheap one, the Tamiya P-51D Mustang in 1/32.
I decanted a bottle of the Krylon and poured it into the airbrush cup.  I started with the gun bay panels, a smaller piece, and noticed it seemed not terribly glossy on the surace of those parts.  I proceeded to the nose of the 'Stang, same lack of gloss.  Then I noticed some actual graying, for lack of a better word, when I started along the wing root.  The paint also looked rather grainy, and not really like a gloss paint at all, and I swiped at it with my thumb.  It scraped off easily.
I stupidly then sprayed some of the Krylon directly from the rattle can onto the 'Stang, which of course resulted in far too thick a coating, and to compound that problem, I used a towel to try to wipe it off.  No can do.  Now I am left with this awful, rough spot along the fuselage.
I would like to attempt to strip all this Krylon from the model, but I have no idea how to go about that.  I typically use lacquer thinner to clean up after a painting session, so I expect that medium would remove the paint, but I'm afraid it would remove plastic as well.  Same thing with acetone.  Does anyone have any suggestions as to what I should do now?  I really do not want to deep six this kit, given its cost but also I was doing a pretty dang good job with it up to this point.
    October 2008
Posted by Don Wheeler on Thursday, June 13, 2019 12:35 PM
Don't try lacquer thinner or acetone.  Fresh paint can sometimes be wiped off with mineral spirits.  If you want to strip the whole model, there are various liquids that will work, including drain cleaners and brake fluid.  Here is a thread with a lot of suggestions.
I have had problems with Krylon lately too. The pigment settled out fast and seems kind of coarse.
I always test spray on some junk plastic before spraying the model.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    August 2014
Posted by goldhammer on Thursday, June 13, 2019 1:10 PM
I'd second Don's thought on brake fluid...wash it down after with alchol, maybe a couple of times so any thing in nooks and crannies gets cleaned out.  Will cause issues with further painting if not completely gone.
    November 2018
Posted by oldermodelguy on Thursday, June 13, 2019 1:17 PM
I think Drano gel formula will take it off fine and it won't hurt the plastic, then rinse with water.But don't wait two weeks to get around to it.
I never found Krylon to be a good answer to model painting except their light gray and their red oxide primers but I haven't even used those now in probably 15 years or so. I think Krylon is great for a cast iron radiator in your bathroom or on lawn furniture, things it was designed to cover. I used to use the black at work and if I recall right it could blush when sprayed in really high humidity.
    July 2013
Posted by modelmaker66 on Thursday, June 13, 2019 2:01 PM
The initial problem may have been that you didn't let the decanted paint "gas out" enough. You need to let the decanted paint settle in the container for a few hours uncovered until the little bubbles of propellent dissapear. Maybe the finish trouble. I always use model paint when I can and avoid household paints. You may also need to sand the kit to get all the paint off. It will come off. Don't trash the kit. Let this be a learing experience.
    January 2015
Posted by Aggieman on Thursday, June 13, 2019 5:17 PM
Thanks everyone.  I think ModelMaker is correct - I didn't leave any time for the gas to dissipate prior to spraying.
I had painted a few parts that will not be needed, and this afternoon attempted several of the things I have on hand prior to running out for some brake fluid or oven cleaner.  Windex didn't work.  WD-40 didn't work.  Mineral spirits didn't work.  But Goop Off did, I think.  I say I think because even though I see nothing wrong with the plastic, it did take the paint right off but I was getting the feeling that if I left that stuff on for too long, it would melt the plastic.
    August 2014
Posted by goldhammer on Thursday, June 13, 2019 5:46 PM
Spray some out of the rattle can on some sprue or not used parts and let dry.  then hit it with brake fluid or oven cleaner and see it if bites into the plastic.  Might have to try a soft bristle tooth brush for the recesses.  Check to see if it scratches the plastic with your choice of agent.
    September 2012
Posted by GMorrison on Thursday, June 13, 2019 9:11 PM
Krylon is crap now. I used to like it, but something has changed.
    April 2009
Posted by Cadet Chuck on Thursday, June 13, 2019 9:22 PM
Yeah, Krylon is good for lawn furniture and boat anchors.
Posted by Don Stauffer on Friday, June 14, 2019 9:13 AM
GMorrison
I used to be a big fan of Krylon, but they kept changing their formulas, and the stuff got worse and worse.  I no longer use it either.
For removing paint I now use Purple Power cleaner.
