Tamiya flat clear hazing?
    June 2018
Posted by TankerEasy on Monday, August 26, 2019 12:38 PM
So its happened to me more than once, and im not sure whats causing it.  Like the title states ive had Tamiya flat clear haze on me more than once, most recently i shot mixed 50:50 with iso alcohol, to which it hazed really bad.  I wet sanded using 3500 grit and re-shot mixed 50:50 with x-20a which cleared up most the hazing, but i still had a couple small spots.  I sprayed it using my Badger 105 xtreme at 18 to 20psi.  Is there something im doing wrong?
Millennial modeler
Air Force vet (2006-2012)
Recently completed: 1/48 Tamiya V1
On the bench: Hasegawa 1/8 Clerget 9B rotary engine, 1/35 scale Trumpeter SA-2 Guideline missle
    July 2018
Posted by Tickmagnet on Monday, August 26, 2019 1:38 PM
I just sprayed my SBD and use the stuff all the time without issues. I typically mix it 50/50 with Tamiya X20A thinner and nothing else. Could be the alcohol you added or your atmospheric conditions.
    May 2013
Posted by Greg on Monday, August 26, 2019 2:42 PM
The .3mm nozzle of the Badger Extreme wouldn't be my first choice for any clear coat. Bigger is better. My guess is you are spraying from too far away and the paint is drying before it hits the model. And yes, I have done that too. I've also had trouble spraying flat coats to heavy and close. I guess you need to find a middle ground.
A tip I learned here is a nice gloss coat over the top of the unwanted hazy finish will make it go away and when dry, you can flat coat over it again.
    June 2018
Posted by TankerEasy on Wednesday, August 28, 2019 8:44 AM
Greg
Thanks for the advice!  I'm gonna try using my Iwata neo for another coat, and ill try spraying a bit closer, would you recommend still doing a 50:50 mix with x-20a and 18-20 psi?
Millennial modeler
Posted by Don Stauffer on Wednesday, August 28, 2019 9:43 AM
It could be humidity.  Rapid drying solvents such as alcohol and lacquer thinner actually cool the surface when they evaporate. If the humidity is too high, the cooling can lower the temp of the paint surface below the dew point.  Water then condenses on the surface giving a frosty effect.  Be sure to check the dewpoint when using lacquer or high alcohol fraction solvents.  Among painters this effect is called blushing.  Google "paint blushing."
    August 2005
Posted by Phil_H on Wednesday, August 28, 2019 11:20 PM
Are you using the clear flat XF-86 or the "Flat Base" X-21? They are very different animals.
    June 2018
Posted by TankerEasy on Thursday, August 29, 2019 5:24 AM
XF-86, and i live in southeast georgia, so humidity is definetly a factor.....
Millennial modeler
    August 2019
Posted by Josh_the_painter on Monday, September 2, 2019 8:24 AM
I just posted in another thread in regards to flat clear, it may help you understand whats happening.
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/t/182743.aspx
I dont know if it will open a direct link or have to copy and paste into your browser sorry.
I hope it helps.
Josh
    April 2019
Posted by Srpuln10 on Sunday, September 8, 2019 11:38 PM
I use Iwata neo and haven't had a problem. My pressure is around what you use. XF-86 is what I use. I've never used the other. So I can't say about the other. Good luck. It's happened to me and probably everyone sometime or another.
2 Cor 6:17
    June 2018
Posted by TankerEasy on Wednesday, September 11, 2019 12:16 PM
Josh_the_painter
I hope it helps.
Josh
Thats some awesome info!  Looking forward to spraying again once i finish the decals and see how it goes!
Millennial modeler
