Techniques for painting stripes on bombs.
    October 2019
Posted by KenK01 on Thursday, October 24, 2019 12:20 AM
I'm currently building a 1:48 F-105D Thunderchief and am trying to figure out how to neatly paint the thin yellow stripes on the bombs. I fooled around for a while tonight trying to figure out a way to use masking tape, but had no luck. The area where the stripes are supposed to be is sort of convex in shape, so getting the tape to lie down flat was an issue I could not seem to overcome. Any advice or tips on how to do this would be appreciated.
Ken
    July 2004
Posted by stikpusher on Thursday, October 24, 2019 1:29 PM
Which type of bombs are you painting? M117 750 lb type? Mk.82 500 lb bombs? Different bomb types had different stripe configurations.
Tamiya makes a thin strip version of their masking tape that is supposed to be good for complex curves. I'd bet it could be used for the compound curves of the bomb stripes. Just paint the yellow first, mask it off, then airbrush on the OD. Another mask that I have heard of being used are the tiny rubber bands used for orthodontics... aka braces. I had a good supply of those when my kids were that age.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Thursday, October 24, 2019 1:38 PM
Tricky. I'd keep trying with the tape. Maybe mark the stripe first with a pencil traced around a circle template hole forced down over the nose of the bomb. Then just go slow with the tape. Start with a strip of Tamiya Yellow that's really thin.
I paint my share of waterline boot topping stripes on ships. Once you get the first side masked, it's much easier to gage the width from there with the second edge. Those are tricky because they get wider as the ships hull goes from vertical to counter, say at the stern. But if it's taken slowly, it will come out fine.
Bill
    May 2009
Posted by Pawel on Thursday, October 24, 2019 3:22 PM
Hello!
My take on that was to take an old tire tube - take your pick if you take bicycle, motorcycle, car, truck or tractor tube. The thickness of it will be the thickness of the stripe. Cut it up in small squares, then paint the bomb tips yellow and let dry throughly. Then you punch a hole in each small square, slightly smaller than the bomb tip diameter. Then you put each bom tip in a hole you just punched, align the pieces of tire tube on each bomb carefully. Then you paint the bombs OD, grey, silver - what they need to be. Remove the pieces of tire tube from the boms and you can admire your stripes.
Unfortunately I don't have an in-progress photo of the process, but here's a photo of bombs painted this way(those are 1/72):
Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    March 2007
Posted by armornut on Thursday, October 24, 2019 6:46 PM
 Might be able to dip the tips, place a drop of paint on a pallet, mark the line with a pencil then dip to the mark, paint fuse last.
we're modelers it's what we do
    July 2004
Posted by stikpusher on Thursday, October 24, 2019 7:21 PM
The challenge comes into play if you do the older multi stripe bombs.
       - Plankton
LSM
    October 2019
Posted by KenK01 on Thursday, October 24, 2019 9:05 PM
Stik, Bill, Pawel, and others who replied:
Thanks for the info. The bombs are 750 lbs (6) and 500 lbs (2). As such, the larger bombs are supposed to have 2 thin stripes and the smaller bombs 1. I'll experiment with some of your suggestions and see what I can do. I really like the idea of marking a line on the bombs first using the circle template to act as a guide. I've got to get one of those! I'm also going to look into finding those small dental rubber bands. I had originally considered using some sort of rubber band, but didn't think I could find any small enough. I also might look to see if I can find some tiny rubber grommets that might serve the same purpose. The type they use like washers on small screws. Lots of food for thought and experimentation.
Again, thanks for the help!
Ken
    October 2019
Posted by KenK01 on Thursday, October 24, 2019 10:38 PM
Stik,
A very enlightening picture showing real bombs. While I am obsessed with getting perfectly straight, clean, and even lines on my model bombs, the real deal was a far cry from neat and clean! But though it may not be realistic, I think I'll stick to trying to make mine as neat as possible.
Ken
    November 2018
Posted by oldermodelguy on Friday, October 25, 2019 4:25 AM
If you can chuck your bombs up fairly straight in a drill then rotate the bomb ( drill running) and just touch the brush or a paint pen against them. Instant line. I do this on Christmas ornament parts all the time on my wood lathe. Not always paint, sometimes using a wire to burn in a line. It works very well, course the lathe has a tool rest. I also do the same thing with epoxy in my fly rod building, the blank is rotating then toouch the brush loaded with epoxy to the wraps and it comes out nice and even.
Anyway think about that and experiment with it. I think you will be surprised how easy it is.
Posted by Don Stauffer on Friday, October 25, 2019 9:17 AM
stikpusher
I tried that narrow tape and do not like it.  It is not flexible enough in the direction perpendicular to the surface.  When I applied it to a round subject to make a curved pattern, it kept lifting up at the edges, in creases.
    October 2019
Posted by KenK01 on Friday, October 25, 2019 10:17 AM
Don, I had the same problem with the masking tape. The edges would not stay flat. Maybe by cutting the width of the tape down to 1/8" it would work better, but I have not tried that yet.
Olderguy, I think getting the bombs chucked up nice and straight in a drill would be pretty difficult, as they have the fins attached. And then there would be the issue of trying to hold the drill in one hand and controlling it, while trying to apply the paint with a bruch in the other hand. If I could get the bombs chucked up OK, maybe I could put the drill in a vice and lock it in place while running? I thought about using my drill press for this, but then the bombs would be hanging down and the paint might run.
My latest idea is to see if using small rubber O rings would work as a mask. If I can find some at my local hardware store today I may give that a try.
Ken
    May 2004
Posted by cbaltrin on Friday, October 25, 2019 10:39 AM
Chuck your bomb in a drill press, turn it on, touch with fine tip brush  with yellow paint. Done. Now if your bomb isn't round or you sanded part of it flat, this won't work too well..
On the Bench: Too Much
    July 2018
Posted by Tickmagnet on Friday, October 25, 2019 10:53 AM
Great thread and just in time because I've taken to preferring using ordinance over drop tanks when available with a kit. Good info here to use for sure.
Posted by Don Stauffer on Saturday, October 26, 2019 6:44 AM
KenK01
Ken
Ken, the narrow stuff I tried was 1/16.
    October 2019
Posted by KenK01 on Saturday, October 26, 2019 6:41 PM
Wow! And the 1/16" tape would not lie flat? I didn't even know that they made the stuff that thin. I fooled around a bit today cutting some of the regular tape down to narrow stips and it looked somewhat promising. Though trying to get enough strips of the same width would be a challenge.
The idea of using O-rings for masks also hit a few snags when I tried it today. I had picked up a couple at my local hardware store yesterday and was optimistic. What I failed to consider was that the 500 lb bombs and 2 of the 750's have a thin rail molded on the bomb along one edge, and this keeps the O ring from sealing around this area. And on top of that issue, despite being fairly flexible, the O rings have a tendancy to creep down the front of the bomb. I'd get them neatly into place and all lined up, and a minute later they had moved out of alignment. Being round in cross section, they don't have much surface area touching the bombs to provide grip. Or mask. So probably O rings are not the answer. Maybe the dental rubber bands would work better if they are more flexible and flat in cross section?
    March 2010
Posted by Nathan T on Saturday, October 26, 2019 7:40 PM
Don’t use straight pieces of tape, cut a curved section of Tamiya tape the width of the stripe using a circle cutter. You have to experiment with the size of curve you cut. The downside is you have to start with a wider section of tape to cut.
    August 2014
Posted by goldhammer on Saturday, October 26, 2019 8:05 PM
How about painting entire bomb then dip the nose in the stripe color, wick off the excess.  After it dries, dip again in the main color and wick off the excess again.  That will leave a stripe whatever width you want.
    April 2016
Posted by GlennH on Saturday, October 26, 2019 10:32 PM
GMorrison
Bill
Don't need for bombs but I will remember this great idea anyway.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
    April 2016
Posted by GlennH on Saturday, October 26, 2019 10:53 PM
Nathan T
Just tried that with a scrap of paper, essentially a semi circle. When you wrap it around it looks like a funnel shape. The only thing is I'm not sure there will be much grab but it did work perfectly.
    October 2019
Posted by KenK01 on Sunday, October 27, 2019 6:34 PM
Nathan,
I can understand how this would work, but I'm not sure about what a "circle cutter" is. Is this a special tool that will cut out circles, like a compass with a blade on one end? Fill me in.
Ken
    October 2019
Posted by KenK01 on Sunday, October 27, 2019 7:05 PM
Have any of you tried using something called Vinyl Fine Line Masking Tape for Automotive Paint? It comes in widths ranging from 1mm to 4mm and is supposed to be used for doing pin striping on cars. The description claims that it is highly conformable and suitable for masking narrow curves. They also claim that it has a low tack adhesive that leaves no residue if removed within 30 minutes. Sounds promising.
    August 2014
Posted by goldhammer on Sunday, October 27, 2019 7:30 PM
Don't know about the vinyl fine line, but the 3M green fine line, at least in the 1/4 inch isn't that flexible for curves.  Norton blue stripe tape is real stretchy, and the narrower widths like 1/16 or 1/8 may work.  Think the Norton may be pretty much like the Tamiya white tape.
    March 2010
Posted by Nathan T on Sunday, October 27, 2019 8:36 PM
KenK01
Nathan,
Ken
Yes, like a compass. Check google, amazon, or EBay
    October 2019
Posted by KenK01 on Sunday, October 27, 2019 9:46 PM
Thanks Nathan! I'll check that out.
    September 2012
Posted by GMorrison on Monday, October 28, 2019 12:41 AM
AND...not to be a turkey a month too early, but...
Get out a good fine point round brush. Pray on it.
Chuck the bomb in a clamp.
Paint a semi circle on one side. Flip. Repeat.
Stick the boomie thing on the bottom of the model.
FaF
    July 2004
Posted by stikpusher on Monday, October 28, 2019 8:43 AM
GMorrison
FaF
Minimize or avoid caffeine intake before doing this... Wink
       - Plankton
LSM
    October 2019
Posted by Tanker-Builder on Monday, October 28, 2019 9:37 AM
Hi;
 I am late here. My idea always works for me. take the Bomb or missile and chuck it in a battery powered large drill. Now take the finest brush you have, or a good brand paint pen. Lay the bomb in a piece of foam with a wedged trough cut in it.  Make sure the part of the bomb you need to paint is hanging out the end.
     Now slowly paint your stripes with that paint brush, dipped in the right color, or Pen of the right color. When done you will be running circles around any bomb you see coming at you! LOL. T.B.
    April 2019
Posted by Tomcat on Monday, October 28, 2019 2:22 PM
I have a slightly different take of the bomb stripes. Here is a 1/72nd scale 105 I dd a while back. Notice the yellow stripe on the nose. I did that by taking and applying a thin strip of yellow decal film. Compare that to the bombs hanging on the plylon. I did those with the paint method (and pretty badly too Sad).
I don't know why I didn't use the decal method for the bombs!?!
Actually it didn't occur to me until I saw this thread. I hope this helps.
Mark aka Tomcat
On the workbench: Monogram 1/24 '69 Pontiac GTO and a Monogram 1/67 (box scale) B-26 Invader
    September 2006
Posted by the Baron on Monday, October 28, 2019 3:53 PM
armornut
That works for me for WW II bombs.  Dip propellor tips, too.
Posted by Don Stauffer on Tuesday, October 29, 2019 9:32 AM
the Baron
armornut
I find for prop tips on larger scales I need a bigger depth of paint than I get on a pallet. I fill the paint jar cap to the depth needed and dip to that.
