Thinner eating away my paint
    November 2019
Posted by Kebin on Monday, November 25, 2019 12:53 AM
Hi all, i have recently just completed a 1/700 build and i have a problem.
After painting the model, i applied Tamiya black panel wash. Then I dabbed a cotton swab with Mr colour Thinner 110(or 120 not sure) to wipe off the excess wash. That's when i realised that the paint are all coming off on the cotton swab.
Prior to painting, I never primed the model. And I'm using Tamiya acrylic rattle can as the main coat. I did not used any gloss coat after spraying either. But I did let the paint cure for more then 2 days. Is that the reason why the thinner is eating away my paint?
I have seen from Youtube that alot of modellers use thinner to wipe off excess wash without any issue but not for my case.
Any insight will be greatly appreciated.
Soorry for double post. If any mods see this maybe can delete it
    November 2018
Posted by oldermodelguy on Wednesday, November 27, 2019 5:02 PM
I'm thinking Mr Thinner thinner is lacquer thinner. You don't generally use lacquer thinner to wash away panels. I'll let someone who use those actual products you mention take it from there, I don't.
    September 2012
Posted by GMorrison on Wednesday, November 27, 2019 5:21 PM
LT will kill any paint finish. I use Turpenoid to wipe washes.
Also highly recommend acrylic gloss clear as a shield for color paint.
    August 2005
Posted by Phil_H on Wednesday, November 27, 2019 5:52 PM
There's several points here.
Kebin
Tamiya spray cans aren't acrylic, they're a "synthetic lacquer".
Kebin
Tamiya panel line wash is an enamel based system and requires an enamel thinner. I haven't used Tamiya spray cans in many years, but I believe that they can be cleaned up with regular enamel thinner, so either way, without an acrylic based clearcoat over the base paint, you're toasted.
Kebin
As mentioned above, Mr Color thinner (the number is unimportant, the "110" is the amount of thinner in the jar -110ml) is a lacquer thinner, and though it's relatively mild compared to hardware store LT's, it will eat basically any model paint.
Sorry there's no good news for you here.
    November 2019
Posted by Kebin on Wednesday, November 27, 2019 7:50 PM
Thanks for the insight guys, now i can see where the problem is. I'm using the wrong thinner - Should have used enamel thinner instead of laquer thinnner. And there's no clear coat to protect my paint. Looked up and I guess I need to get the Tamiya X-20 thinner and X-22 clear coat then.
    November 2018
Posted by oldermodelguy on Thursday, November 28, 2019 5:37 AM
Kebin
For wiping enamel or oil washes I use odorless mineral spirits personally. Very lightly dampened tissue seems to work. FWIW Windsor Newton now has a line of oil paints that is water clean up ( just putting it out there).
    November 2019
Posted by Kebin on Saturday, November 30, 2019 8:39 AM
Alrite so I proceeded to get myself a bottle of tamiya thinner. And to my dismay when I reached home, I realised I bought the X20 enamel thinner instead of the X20a acrylic thinner. Can it be used to wipe away the excess wash? And I'm also planning my first airbrush, using my existing tamiya acrylic paint. Can I use the X20 to thin the paint or do I need to get the X20A instead?
    August 2005
Posted by Phil_H on Saturday, November 30, 2019 9:07 AM
Firstly, the good news. X-20 enamel thinner is the right stuff to use for cleaning up Tamiya panel line wash.
The not so good news, yes, you'll need X-20A acrylic thinner to thin Tamiya acrylic paints.
