Cleaning Acrylics from Airbrush Using Ultrasonic Cleaner
    December 2019
Posted by Niko on Friday, January 3, 2020 10:29 PM
Hello,
I have an ultrasonic cleaner for jewelry which I use for my airbrush. I would fill the tub with soap and water to clean it but the process doesn't seem to work wonders. I airbrush acrylics (Vallejo and Tamiya). I did some research on the best solutions for cleaning airbrushes and these were the suggestions from online:
  • 100% Ethanol
  • Rubbing Alcohol
  • Ammonia Free Windex
  • Vallejo Thinner
  • Tamiya Thinner
I have only tested with rubbing alcohol and will try some others soon, but what do you guys think? Is there a better solution to water and soap for cleaning acrylics from an airbrush?
Thank you,
Niko
"The farther back you look, the farther forward you are likely to see." - Winston Churchill
IN PRODUCTION:
Trumpeter KV-2 1940 1/72
Tamiya Flakpanzer IV Wirbelwind 1/48
    July 2013
Posted by modelmaker66 on Friday, January 3, 2020 11:45 PM
Alcohol is flammable and the ultrasonic cleaner heats up. Don't use it! Use soapy water. Dish soap 2-3 drops and water.
    November 2018
Posted by oldermodelguy on Saturday, January 4, 2020 6:19 AM
I don't do a full tear down on my brushes often but when I do I just soak everything overnight in lacquer thinner. But I don't use a US cleaner. Everything come loose or is even gone in the morning. I find if I really flush well immediately after spraying I can hold off a tear down for two to three months. Just on double action brushes back off the needle chuck and slip the needle back off it's seat a liitle is all or it may stick, regardless how well it was flushed.
I doubt many US cleaners would be rated for use with alcohol or lacquer thinner but then I don't know a lot about electric powered ones. The solvent ones we had at work were air operated though.
    August 2005
Posted by EdGrune on Saturday, January 4, 2020 7:04 AM
A caution against using an ammonia soak, in an ultrasonic cleaner or not.   Ammonia will affect brass.  Even a scratch in the chrome plating will expose the underlying metal.   A soak in ammonia will lead to corrosion of the base metal.
A quick spray of ammonia, a dip, or a wipe with a soaked Q-tip is ok.   It's the soak that is the killer.
Posted by Don Stauffer on Saturday, January 4, 2020 7:14 AM
modelmaker66
It depends on which alcohol.
Methanol certainly is quite volatile and burns with a clear flame that can be dangerous. On the other hand, isopropyl is quite safe in the reasonable concentrations.  Don't know about the 97%, but the lower percent stuff is pretty safe.
    December 2019
Posted by Niko on Saturday, January 4, 2020 10:06 AM
Late last night I did a full tear down and cleaning with 70% Isopropyl and it came really clean.
My trigger action though seems a little stiff, is it safe to put some Remington oil to lube the trigger action?
IN PRODUCTION:
    November 2018
Posted by oldermodelguy on Saturday, January 4, 2020 11:42 AM
Niko
The sliding action for paint flow ? Maybe you just have the return spring set a little too tight.
For lube I use glycerin if anything at all.
    May 2013
Posted by Greg on Saturday, January 4, 2020 1:43 PM
I also use an ultrasonic cleaner on my airbrushes.
I use a jewelry cleaning powder that came with one of my ultrasonic cleaners. I'm not sure this is the exact product I use, but it is the same idea and this is where I will probably go to buy when I run out.
FWIW, as long as I clean the airbrush immediately at the end of a session, I don't really use the ultrasonic cleaner that much. But it can help with stuck on messes.
    December 2019
Posted by Niko on Saturday, January 4, 2020 5:19 PM
Greg
Thanks for the tips everyone! I took a look at ultrasonic powders online and the key ingredient in most is potassium peroxymonosulfate, a powerful oxidizer used in pools. The ultrasonic powders are essentially non-chorine shock for pools packaged in smaller containers at a higher price.
Next time I clean the airbrush with the ultrasonic cleaner, I will try the non-chlorine shock.
IN PRODUCTION:
    May 2013
Posted by Greg on Sunday, January 5, 2020 12:00 PM
Niko
That's interesting.
