Of the several brands I've tried, Tamiya acrylic is my favored one. It's a no drama paint, thinner can be water, alcohol, lacquer thinner, or their X-20A or their lacquer thinner. I use mostly X-20A, or their lacquer thinner.
Once you get the thinning ratio worked out to what works best for you, Tamiya produces a very smooth painted surface. It adheres very well, I can't say I've ever had any lifting when removing masking tape.
I thin 50/50 at the start, usually settling on 60 or 70% thinner after spray samples dictate. Using Badger gravity feed airbrushes, I spray at 15-20 PSI.
Cost wise it provides a larger bottle than most, and for very little money comparatively. If your hobby shop can't supply you with it, you will find several on line dealers.
I recommend always giving the bottles a complete stir to blend the ingredients, just shaking the bottles does not thoroughly bring all of the settled materials off the bottom.
Hope you like using it, if you try it.
Patrick
