Can I use other name brand pigments with my pigment fixer I have now. It's AK pigment fixer. Or do I need to keep name brands to its own kind
2 Cor 6:17
Tks. I didn't think it would matter but honest to goodness I didn't know. I didn't know that you could use the other things you mentioned. What's the best way to get the pigment to build up say like mud or dirt. I know that rust is something that doesn't build up like mud and dirt. I've seen a lot of models that has build up of mud and stuff and just wondering how it's done. And tks again
I have mixed in some plaster of paris to give it texture if I wanted it thick.If I wanted not a lot of buildup,you can also just put them on a little thicker and instead of mixing them,just wet them enough to fix them instead of spreading out.It's hard to explain,try some Youtube videos
Tks Tojo for the info I'll be trying that in the next few minutes
