Bubbles in cup!!!
    January 2004
Bubbles in cup!!!
Posted by superviper88 on Friday, April 9, 2004 11:28 PM
Hi, i have a double action brush that keeps on bubbling in its colour cup after about half an hours use. I presume its because of a clog in the tip. It can be cleared, but the paint flow wont be that strong anymore. This happens everytime i spray, yet my paint is already very thin. im pretty new to airbrushing... does this happen often? thanks...
Posted by Anonymous on Saturday, April 10, 2004 12:45 AM
Probably you have an air leak in your airbrush. Try to check the area between the tip joins the noozle.
Posted by MikeV on Saturday, April 10, 2004 1:09 AM
You are correct, that happens when the tip becomes clogged with paint and it begins to backflush the air into the color cup. What I do is blast as much paint as you can for a second to clear it and then try and clean the tip of the needle off as best as possible.
Posted by Anonymous on Saturday, June 12, 2004 1:51 PM
I have bubbling problems also with my Iwata HP-CS. I've checked everything and there seems to be no poblem with my airbrush. The instruction manual that came with my Iwata says that it might be of my nozzle,/body seal, cracked nozzle. But i can't find anything wrong with these parts.
