First time using Tamiya with lacquer thinner, I have a question
    June 2012
Posted by Compressorman on Sunday, February 23, 2020 7:25 AM
Just finishing up painting my F8 Crusader with Humbrol enamel. I am planning on using (for the first time) Tamiya gloss clear thinned with Mr Leveling Thinner but am wondering if the lacquer thinner will wrinkle the humbrol enamel. I do not have any tamiya thinner and am wondering if I should thin the gloss clear with alcohol instead of Mr leveling thinner for the first coat? I do not have a local shop where I can go buy the proper tamiya thinner and am wondering how the alcohol would work should it be neccessary to use instead of lacquer thinner.
I have always used either enamels or water-based acrylic and have zero experience with Tamiya acrylic.
    November 2018
Posted by oldermodelguy on Sunday, February 23, 2020 1:46 PM
 I've only done what you're asking once and it was over months old enamel ( and it was Model Master enamel) with a couple of coats of Pledge on it. It went well fwiw. But with fresh enamel and no barrier all bets are off from my view. You would be best off to conduct a test first. Maybe someone with more experience using that specific combo will chime in. I use a pretty fair amount of X22 clear thinned with lacquer thinner but it's a rare day I clear enamel at all fwiw. If I'm headed towards a clear coated finish it's likely I'm using lacquer or acrylic color coats.
    May 2004
Posted by cbaltrin on Sunday, February 23, 2020 2:34 PM
I dont Tamiya lacquer directly over enamel is a good idea.
On the Bench: Too Much
    March 2013
Posted by patrick206 on Sunday, February 23, 2020 3:30 PM
Years ago, actual paint store lacquer thinner over enamel meant you painted the project all over again, after removing the mess that was made. Now it seems that what the hobby paint companies call lacquer thinner, isn't the same as long ago. The modern clear coats and thinners are much more compatible with each other.
Spray a patch of plastic with your enamel, let it dry for a couple of days, then spray light coats of your Tamiya clear thinned with the Mr.Color stuff and see if it reacts at all. My thought is it will work OK, I've used it with good results.
Lawdog is a fan of it, hopefully he'll stop by and give some real input about it's use. If you're still in doubt, Tamiya does thin very well with alcohol.
Patrick
    June 2012
Posted by Compressorman on Monday, February 24, 2020 10:47 AM
This problem was never suppossed to be a problem. My plan was to use Mission model gull gray to paint the plane but it performed terribly. This was my first time using gull from Mission models (other colors have historically done quite well) but even my Patriot with the big old primer spraying needle/nozzle kept gooping up on me and it didnt matter how much I thinned it. Had to go back to my trusty tim of Humbrol and now I have this lacquer thinner worry. I think I will try thinning the clear with some alcohol and see how it does, sigh.
    November 2008
Posted by plasticjunkie on Monday, March 9, 2020 6:40 PM
Compressorman
kool
Did you contaminate the MMP with solvent residue? Did you over thin the MMP? I'm an enamel user and for the first time yesterday  I used MMP cammo grey on a 105G I'm working on and was pleasantly surprised at how smooth the MMP sprays.
 GIFMaker.org_jy_Ayj_O
