I recently bought an Iawata hp-cs, and have a compressor.
While airbrushing my model with primer, I noticed small and medium sized droplets of primer appearing on my model, obviously sputter marks. No matter what psi I used, (15-50) I couldn't get my airbrush to stop sputtering. Never before had I touched the needle, and I had thinned the primer (1part paint-1part primer, 2-1) Did I get a defective airbrush, or am I doing something wrong? (btw, the primer was model master's acry, and I thinned it using tamiya's acryl thinner, another btw, can I used water to thin out tamiya acryls in the airbrush cup?)
Also, I noticed when sanding the putty to fill large areas(parts of the wing of an jet weren't level, so I used some putty to sand and level them) I can notice observe little bubbles and sanding marks in the putty...I didn't use any acetone based nail polish to coat the putty...will the polish make the putty look smooth and not end up looking scratched and bubbly(little holes in putty)?
~Your input would greatly be appreciated!~
-=D00/\/\ G|vER=-
