Just got done. Hase called for half Naka and half Mitsu interior green. I added about 3-4% AK thinner just because.
Three light coats covered well, shot at around 20PSI from my NEO. Used about 3/4 of the large cup on the gun. Did the entire interior, cowl, wheel wells and canopy frames
I didn't prime, as there won't be any issues once she's buttoned up (going with closed canopy). Laid out flat without any issues. Cleaned up with tap water and a run through of a couple cups of Iwata acrylic medium cleaner, with a back flush and wipedown.
Will see what the outside does when I get that far, as it is several colors and will require masking, Will prime exterior, probably with MM laquer primer.
So far, I like it.
