Model Master semi gloss Acryl caused smear - HELP!!
    October 2016
Posted by Mrchntmarine on Tuesday, July 21, 2020 3:30 PM
So now im thoroughly confused.  This model has been hull painted for a long time.  The bottom and above the bootstripe is AKI and the stripe Tamiya acrylic.  I just brushed on some MM Acryl w/ a tad bit of water to thin and the black smeared.  The MM isnt suppose to be thinned more, right?  Ive never before...  Any ideas what caused the black to smear after drying so long?  Trying to figure out what i did wrong here.  Oh, any way to remove the smear before too long?
Keep on modeling!
All the best,
William
    October 2019
Posted by Tanker-Builder on Tuesday, July 21, 2020 5:40 PM
Hmmm;
 Hard to tell. I will say this though. That's one of the reasons I NEVER liked M.M. acrylics!
    October 2016
Posted by Mrchntmarine on Tuesday, July 21, 2020 7:34 PM
Tanker-Builder
Hmmm;
whats your preference For acrylics ?  Have to say Ive usually sprayed gloss and flat when I've used it before with no issues. I'm stumped on the smearing though....
Keep on modeling!
All the best,
William
    April 2020
Posted by Eaglecash867 on Tuesday, July 21, 2020 8:08 PM
Model Master Acryl paints all seem to be ammonia based, so they'll eat just about anything off when applied with a brush.  If you're stuck with using that, try airbushing it on...it should dry quickly enough so it doesn't mess with the colors.  I had a bunch of MM acrylics at one time, and when I found MM enamels to replace them...I chucked them all...they're pure garbage.  Tamiya makes a rattle can of semi-gloss synthetic lacquer, TS-79.  Haven't used it, but it might be worth a shot.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    October 2016
Posted by Mrchntmarine on Wednesday, July 22, 2020 5:14 PM
ok, so what is this stuff??  Like i said ive brushed before with no issues but ive really used it much more airbrushing....  Just reading the label now - havent in awhile. Reads water clean up but if you want to thin use #50496 Acryl Thinner.  And to clean airbrush after use, use Acryl Solvent #50498.  So if its water based, why do you have to use the other stuff?  Does anyone use this stuff?  What say you?
PS - their website is terrible
Keep on modeling!
All the best,
William
    July 2013
Posted by modelmaker66 on Thursday, July 23, 2020 12:55 AM
It won't be an issue much longer, The line is discontinued.
    September 2012
Posted by GMorrison on Thursday, July 23, 2020 1:10 AM
Chemistry.
Don't try it again, right?
Bill
