Removing Mr. SuperClear from windshield
    September 2019
Posted by AndrewJosie on Tuesday, August 18, 2020 3:24 PM
I "Mr. SuperCleared" my Tamiya Porsche 911 Turbo after installing the windows and now they are all fogged up and caked with Mr. SuperClear.  Any suggestions for how to remove Mr. SuperClear without damaging the windows?
Andrew
    April 2020
Posted by Eaglecash867 on Tuesday, August 18, 2020 4:33 PM
It looks like Mr. Superclear is lacquer-based, so unfortunately, your windows are probably already damaged beyond repair.  Testors Gloss Cote and Dull Cote are also lacquer-based, and I found out the hard way what happens to clear plastic when its exposed to lacquer.  Luckily though, Tamiya is pretty good to deal with for getting replacement parts.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Wingman_kz on Tuesday, August 18, 2020 4:59 PM
Yeh, if you could get replacements that's probably your best bet.
I use Castrol Super Clean or Purple Power for paint stripping. They won't damage the plastic. At least it hasn't hurt any I've used it on including clear parts. Full strength, undiluted but wear dishwashing or rubber gloves while handling and if you splash any on bare skin, rinse immediately.
If you decide to try and save these parts then soak them in a tub of this stuff for a day or two then wash them off. I use dish detergent. Sometimes it takes longer but clear will probably come off fairly easy.
Then, if they aren't too crazed and you think you can save them, or want to try, get some Micromark polishing cloths or pads. Start with the most coarse grit and sand until the crazing is gone. Then use the next finest cloth and sand/polish until the marks from the previous grit is gone. Repeat until you've gone through 12000 grit. If you sand in one direction with one grit and then across that diagonally with the next it will be easier to see when all marks are gone from the previous.
When that's done you could use Novus plastic polish to get the parts looking new. Or, you can dip them in Future or Pledge floor polish (or whatever it's called today). I stick a piece of tape on a corner edge, just enough to hold it, then dip the part in Future and lift it out. Let it drip for a minute and then touch a bottom corner to a paper towel to wick away any excess. Hang them up somewhere there's no dust stirring and give them a day or overnight to dry.
Yes, it's a long tedious process but it can work. To get rid of scratches or whatever. Not saying you can save those parts but if you want to try, that's how. And be careful handling them, clear parts break fairly easy.
    September 2019
Posted by AndrewJosie on Wednesday, August 19, 2020 6:47 AM
Thank you!
