Pressure Switch for Airbrush Compressor...
    October 2006
Posted by JunJon on Sunday, August 30, 2020 9:52 PM
Hi,
I have this compressor...
https://www.anest-iwata.com.au/products/airbrushcompressor/is925ht
and connected a air tank extension...
https://www.hlj.com/air-tank-hpa-tnk35-aiwhpa-tnk35
On the tank extension. The max pressure it can hold is around 87psi.
The compressor max pressure is around 60psi.
My question is...
Can I adjust the compressor pressure switch to match the tank extension max pressure capacity? The bleed valve is another thing I need to figure out also.
    April 2004
Posted by Jon_a_its on Monday, August 31, 2020 5:42 AM
JunJon
My question is...
You could, but unless you need to pump tyres or run a nail gun, why would you?
Typically, I run my Iwata HP-CS & Badger 4000, between 20-25 PSI, or up to 30-35 PSI when spraying Badger StyNylRes, & even my TRN-1 knock-off doesn't need 60PSI, so I can't think of a modelling reason to need 78PSI?
The Iwata compressor is a good bit of kit, & you will considerably shorten the service life if it if you run it over spec. It also has a handle as the tank, but connecting a tank is also a good idea, as the max pressure is higher than the compressor max.
It produces 36L/M which equates to 1.271328 cubic feet per minute, which is more than adequate to run an airbrush or two.
The Bleed valve is designed to prevent damage to a: the compressor, & b: preventing the tank exploding, I wouldn't mess, experiments will tend to hurt!
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    October 2006
Posted by JunJon on Monday, August 31, 2020 8:08 PM
"You could, but unless you need to pump tyres or run a nail gun, why would you?"
my setup...
Just to max the extension tank capacity. Its only filled around 0.4+ MPa or 60 psi.
Then again theres the bleed valve. As you said, its designed to function on a certain pressure. I guest I just have to leave it as is since I'm not certain also with the bleed valve.
Thanks
    May 2009
Posted by Pawel on Tuesday, September 1, 2020 4:16 AM
Hello!
Can you show a photo of the pressure switch itself? Preferably with the housing off? Usually it's a question of adjusting a screw on a spring to manipulate the pressure or pressures (on and off).
There's the safety valve - it's rated opening pressure should be stamped in the metal on it. It's usually much higher than the "off" pressure of the switch.
Hope it helps - have a nice day
Paweł
www.vietnam.net.pl
    October 2006
Posted by JunJon on Wednesday, September 2, 2020 12:06 AM
Thanks Pawel. Will build up the courage on removing the cover for the pressure switch. Will update you. Cheers.
    October 2006
Posted by JunJon on Wednesday, September 2, 2020 7:06 PM
Pawel
Hello!
PaweÅ‚
Hi Pawel. You can see the pressure switch is somewhat different from a big compressor.
Not sure yet how to open this. The bleed valve is rated 100psi just for your info.
Cheers
