Deaf Smith
Thank you, Ed. I had not even considered the line diameter and length factors or, thanks to you, pressure gauge accuracy. LOL. I'm going to employ your protocol. Thanks again.
Okay, so this is overkill, but it might be somewhat relevant and useful. I have tables for air flow in steel pipe, so selecting std Sch.40 1/8" pipe (0.269" ID) and assuming a typical compressor produces 0.8CFM at 57psig (and assuming 70F), the pressure loss would be ~0.188psig per foot of pipe. Assuming the air hose is 6', that's just over 1.1psig pressure loss in the hose. At lower pressures, that loss goes UP (e.g. 20psig, 2.3psig loss). Anyway, if you assume it's a good gauge with ~1% full span error, you're probably looking at an almost indistinguishable loss vs the gauge error.
Me, I have fun doing this math, but I set my pressure with the airbrush trigger engaged and will be adjusting it for performance. Given I have a different hose, airbrush, ambient temperature, etc. than most others when I read PSI recommendations, I just assume it's a starting point!
Finally, if you want numbers for a particular diameter, let me know and I'll do the math!
Edit: I forgot to mention, this is assuming a tankless compressor at a flow rate that it can just keep up with - i.e. max flow while maintaining pressure. If your flow rate is lower than that 0.8CFM, your pressure loss drops significantly. E.g., 50% of the flow results in 25% of the pressure loss.
